Erratic/high idle when warm, hunting idle when cold
Firstly hi all, not posted before but have been around for a while.
Just bought a DR350, fitted with a Mikuni pumper carb with standard jets (TM28) having been for a ride I found it won't idle properly when it's cold the idle speed hunts up and down a little. But when it's warm/hot the idle hunts more severly and if i rev the engine it sticks at 4000rpm increasing slowly to 5000rpm by itself, sometimes it will suddenly drop off and almost stall other times it just stays at 5000 until i let out the clutch or rev the engine again. Oh and it's very very hard to start without damp-start.
I've tried a few different things to no avail...
Adjusted the pilot screw - No effect whatsoever other than slight popping/banging when on leanest position.
Checked the slide wasn't sticking.
Dropped the needle a few notches (appeared to improve situation slightly)
Checked for air leak on carb rubbers.
Checked all jets for dirt-all were clean.
Checked float needle seal and seal O-ring.
Removed air filter (filthy) - Appears to have improved cold idle.
What should I be looking at next?
Can anyone point me in the right direction.
-Flank
Hmmmmm looks like I was searching under the wrong terms "Hanging idle" seems to have brought up a few similar threads, all suggesting the problem is a lean idle.
Will have a go with a bigger jet tommorow.
I would start looking for air leaks in the intake tract post-carb
Aye checked that to start with but no joy :busted:
Forgot to mention the idle goes sky-high if I pull the choke out.
Hmmmmm, not having any luck here at all, I've checked EVERYTHING that there is to check on the carb and it's all fine, I've fixed all fuel leaks, cheaked the rubbers thoroughly for air leaks and even cleaned the air filter.
Yesterday I even tried a multitude of different jet sizes which all effect the general running as you would expect (small ones making it pop and bang big ones making it bog down)
BUT NOTHING I have done has had any effect on the hanging idle which randomly sticks at around 4000 rpm when revved regardless of whether it's running lean or rich or anything else. Sometimes it drops right back down and bogs out sometimes not.
So is there ANYTHING BESIDES the carb that could cause a random hanging idle? valves/timing/de-compression lever etc etc?
Does have a hot start or a tps?Not to familiar with these bikes, but ill try to help.
EDIT: I did some searchin around, and it seems that alot of dr owners experience the exact same symptoms as you because of a "sticking choke". I would clean all choke components(plunger,linkage,cable,etc), and then see what happens. Happy trails:thumbsup:
Interesting I'll have a wee-look tommorow, thanks for the input.
On another note I found that the Pilot Air jet was completely missing. SO I fitted one from another old carb I had laying about to see the results and it had quite a dramatic effect.
No longer does it hang at 4,000 rpm
It now hangs at 6,500rpm
Bugger
  • Similar Content
    • By Nicturner
      Hi fellow thumpers,
      firstly if there is other threads on this topic I apologize.
      i have a 2009 KTM 450 exc. I live at 5500 feet. I have a keihin carb. I currently have it set up with
      green needle (jd kit) @ 4th from the top
      main #175
      pilot #42
       in setting it up for some desert riding I plan on doing next month (LAB2V). Right  now I’m getting a bog if I rack the throttle a few times. I’m reading this is semi normal as the accelerator pump has a hard time refilling.
      i have put a new diaphragm, spring, lean jet is at #40 and air fuel acre 1 and 1/8 out.
      im planning on going back to 172 main, red needle 5th from the top and #45 pilot.
      i normally ride the trails around lake arrowhead and Big bear in California. The trails are single track from 5000-10000 feet.
      Anyone see any issues with either set up?
      how about the big if I get on it a few time ( not really noticeable when riding)
      sorry for the questions. This is my first carb I’ve ever worked on.
      Thanks in advance
    • By SNORE125
      Anyone else have 130 main and 38 pilot jets already in the carb I took the wifes ttr 230 carb apart to add the bigger jets and this bike from 05 that I bought new already had them in it? I was reading that they came with a 125 main and a 36 pilot.
    • By Charles Joseph Miron
      Hello all.  Need a helping hand here..
      I bought an older TT225 and am not about to spend almost $600 on a new carburetor for it. So I'm hoping someone can help me out with an idea of what (other than original carburetor) style, type and brand I should go with..  I'm also having a bit of trouble finding info on this bike.  It's a 1986 Yamaha TT225.
      Thank you in advanced
      Charles
    • By Br0ck
      Hey guys, I went on vacation all summer and let my bike sit (2002 CR250). When I got back I ripped it apart and cleaned carburetor and put it back together and it started fine and ran alright, but idled really high. I adjusted the idle screw and realized it was a ridiculous amount of turns out. I can't remember exactly how many but id say 6+ turns out. My killswitch was a POS and didn't work anymore so I replaced it with an oem replacement. My last ride I crashed the bike pretty bad and I was off the bike for 2 weeks. I can't get the bike to start ever since I got installed the new killswitch. I think I wired it right I just replaced one wire at a time and it looked pretty straight forward. I verified it by testing spark while holding it in I was getting no spark but with it in running position it would spark.
      Anyway I am just looking for some base settings for the Mikuni TMX to get my bike running again, my carburetor has a 35 Pilot and 380 Main jet which appear to be stock. I am located in Edmonton, AB, Canada which is about 2500ft and usually ride between 10-25 celcius.
      Thanks for any replies.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
