gas tank
07 - the top hole where the 8mm screw fits no longer holds tight and I lost the screw - How do I fix this? Do i need a new gas tank or should i try a 10mm screw?
this is the 1st kawi I've had and the 07 kx250f has been quite an experience:
1. locked up hot start at the carb - had to replace the entire carb - luckily this happened under 30 days and cost me 0
2. broken front break levers - stock ones broke a lot - now use asv
3. oil drain plug became stripped out - had it retooled
4. the timing bolts blew out during a race
5. lost 2 spokes on the front wheel
6. jetting
7. lost screws and bolts here and there
now the tank issue
6. jetting
now the tank issue
Not to be an a**hole, but all those things you mentioned are due to poor maintenance. In my opinion.
1. all stuff needs to be lubed.
2. Is it Kawi´s fault that you crash?
3. Get a torquewrench.
4. Check your bolts more often.
5. Check your spokes more often.
6. Jetting changes with weather. Kawi don´t know where you ride.
7. Check your bolts more often.
About the tank bolt, did you try to tap it to clear the threads and use a longer screw?
+1:thumbsup:
LOL
95% of the issues I mentioned were after a two week period of riding the bike. No, it's not Kawi's fault that I crashed and broke the front brake. Local shop should have "prepped" the bike. Just venting and my biggest concern with the kawi is craftsmanship; the bike it very HM.
I'll probably tap it as a longer screw would dig into the tank and gas would leak out, right?
What screw are we talking about exactly? I thought you meant the one in front, holding the tank to the frame?
Btw, all screws in the tank and shrouds are 6mm. They have 8 mm hex heads.
