XR 600R rebuild question
It looks like i have had a problem with the oil pump. Seem the the top end did not get enough oil. I have a small amount of scaring on the inside of the small hole on the push rod where the piston attaches. Dose anyone have any ideas on how to remove the scars without replacing the push rod. Thanks
Connecting Rod ?
Small end bearing?
Is this motor oil feed through a small tube and banjo bolt to the top end?
If so you can open the hole through the bolt.
Welcome to TT!
Can you post a pic of the part?
If it's bad, it should be replaced.
yes the oil is fead by an external conduit to the upper valve head. i checked everything for cloging and found none. i think it is the oil pump but im not sure how to check to see if the oil pump is working.
You have to upload the photos onto a hosting site like www.photobucket.com and post the link here so we can see it.
I doubt it was actually an oil pump failure. Not impossible, but doubtful. It is much more common for the oil level to get too low through neglect or for the frame strainer to get clogged and starve the pump/engine.
If your connecting rod small end is scored/galled, then the valvetrain should be in even worse shape. If the valvetrain is fine, then it probably wasn't oil starvation. And no, there is no long-term fix for the rod small end. It most likely needs to be replaced.
Thanks for the help
Man that sucks it looks like hell.
A complete rebuild for that one.
Yeah, that rod is toast.
Looking at all the crud squeezed out around the base gasket, I wouldn't be at all surprised if you find a bunch of dried silicone in one or both of the oil strainers.
The condition of the rod indicates oil starvation and/or serious overheating. It is galled pretty badly, I would replace it.
+1 on all the above.
I should have mentioned in my previous post that judging from the condition of the rod, it would be a good idea to check the camshaft and rocker arms for damage.
yea i think your right. thats probly what caused the lack of oil in the firs place.
did that and you are right thrashed one lifter arm and spent the cam
  • Similar Content
    • By mrdsee
      ~177 Titanium bolts, nuts, washers etc leftover from various motorcycle projects. XR650, YZ 125, YZ250 a mix of new and used once hardware.
      Made by Mettec
      Over $2k worth of hardware
    • By Xr600guy
      So I don't seem to find my specific issue so here I am asking.
      I have a 1997 Xr600r. It was recently re-jetted and has ran really well ever since until more recently it has begun to have this issue.
      Everything works fine. Kicks right away, nice and easy. Runs great, sounds great, purs. But when I'm downshifting and slowing down to a stop, if I let my hand off the throttle that's when it just dies. I found that I can counter this by lightly holding the throttle as I down shift (so I'm revving quite a bit during downshift).  But it hadn't done this before.
      The only thing I've done that I suspect may have been an issue on my part was when I pulled out the engine to change the valve cover gasket and upon doing so perhaps when connecting the carb back to it, I may have missed something or made a crack in the boot?
      Any ideas? Thanks
    • By Kenya
      Hello all,
      There's been a lot of talk about how to register a dirt bike in states that don't allow it.
      I just moved to North Carolina and for the first time in my life might be able to afford a bike. I've been dreaming about an XR650R for a long time, but they're not cheap. Plated bikes seem to be more expensive too. So here's my question, has anyone tried to plate a dirt bike by adding all the necessary features and having it inspected as a custom bike? Anyone know of another way I can plate an xr650 in NC?
    • By Jsmoot
      Hoping for some help before I throw in the towel and end it all!
      Engine starts fine, runs and idles well for +/- 10 minutes, but cuts out while riding once the engine warms up (175 - 185) and intermittently cuts out thereafter (any speed/gear). It will start up after 30 seconds or so (but won't run for long before dying again). No spurting or surging.. just dies.
      I've replaced CDI (twice), Spark plug, spark wire and coil, and most recently pulse generator. I do have a 41mm Flat side carb from a CRF (and it has more power than the old carb setup), breathing through a Uni filter. Also, sealed battery tender battery (hasn't shown low when trickle charged).
      What's next on the test/replace list? Stator maybe? Please help...
    • By Richard Stevens
      I found a buddy that’s going to help me with the “Dave’s Carb Mod” after that what size jets should I order before we begin? I’m in Cols Ohio and 1140 above sea level. Should I just order the Dyno kit or FMF kit or should I just go to jets r us and order 2-3 from there? Thanks all so much help. Love it. Stay safe out there.
