Upper Shock Bearing
How do I go about changing the upper shock bearing? I have never done this before and my manual isn't very descriptive. I guess people are already expected to know how to do this, unfortunately I am unsure and any help would be appreciated. Thank you very much. It is a 2001 cr 250 if it matters.
Take out the shock. There is a little C-clip holding the bearing in on one side which you probably won't be able to see. Rig up your threaded rod/washer or whatever you're using and push the bearing to one side (away from the C-clip) so you can get the c-clip out. Once you get the c-clip out then you push the bearing out the opposite way that you pushed it first and it'll come out. I know this sounds weird but once you start it you'll know what I"m talking about.
keep in mind that clip is one pita to remove......you'll need two sharp pointed tools (like dental picks) one to get under the wire and one to stop it from spinning. like tod says make sure to push it away from the clip first. a little heat from a heat gun (or propane torch) to expand the aluminum(try not to heat the bearing itself,and don't heat past the point you can't touch it) makes it easier.:busted:
A socket works really well. It pushes on the outside of the bearing and doesn't hurt the ball part.
We were servicing mine when we damaged it:O Lucky you are replacing yours! I should have come to ask for help. You may even want an extra hand, 4 hands help in this situation, and even more so if you heat it up
Ride Safe
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
