Fatbars on 83 XC
Found a way to mount 1 1/8 bars on my 83 XC250..I was looking at my parts bike 05 YZ250 and noticed that the applied triple trees on the bike looked very similar to the ones on the husky. I took them off and sure enough the bar mounts worked great in the husky top tree..I bought the applied trees off ebay for $30 a couple of years ago...
Can you send a picture of what you did to get the fat bars to work? You actually used Yamaha triples for the 40mm forks? Please let us know. This could be a well kept secret? Thanks. Mike
Sorry. My bad, you used the handle bar clamps off the Applied triples. Do they allow you to slide the forks up and down in the clamps? Mike
You can buy a $30-40 set of Pro Taper clamps, drill the husky sleeves out for the slightly bigger mounting bolt, and your in business.
Scoott,
DO you have any pics of your frame rake. I am interested to see were you put the steering stops..Did you move the tank forward? I was thinking of putting the tank a inch forward and drilling throught the frame and welding in a sleeve to attach the tank to the frame..It looks like there is room between the gas tank and the fork tubes to allow for full side to side movement of the forks...
I've put 5 sets of the Pro Taper clamps on 80's Huskies. With the offset post it actually gives you the option of close to stock or a moved forward position. Since I am 6'3", I prefer to move the bars ahead.Only thing you need to do is drill out the Husky sleeve to fit the larger mount bolt.
And throw away the bar clamp bolts and replace with stronger bolts. I broke 3 bolts torquing down with a 1/4" T-handle.
The Pro-Taper mounts are also black, so they look like they were meant to be there.
Sorry, don't have any Pics, Maybe I'll try to get some. I modestly think I have the trickest 83-84's I've seen. But I'm always open to ideas.
At the Washougal Hammer&Tongs race last year, the fastest rider there (Ex pro motocrosser Grayson Hart) told me he thought my 500 Husky went through the whoops as good as anything there.
Scott
Thanks for more info., I crushed my arm in '04 and the FLEXX bars are a necessity! I will be racing my ' 82 430 and 420 this year.
I can relate......I got both hands in a hay baler when I was 10 years old. COuntless surgeries over 3 years and I ended up with 2 3/4 fingers on one hand and 3 1/4 on the other. Then I decided to pick motorcycle racing as my sport for life.
I have always fought to hold onto the bars.
Haven't tried flex bars yet.....keep hoping someone will show up at my track that I can talk into trying.
Damn Scoott, thanks for the inspiration. You are a true hero and I am so glad motocross has become your sport after all you have been through. I hope to meet you at one of the VDR this winter or a Hammer and Tong events this summer.
I really want to see pictures of your 500 Husky, please post some or PM me and I will send you my email address. I plan to build a 84 XC500 after I finish my current XC250 project and need some great ideas. It sounds very trick. Do you know of anyone using an aluminum swingarm with the Huskys? They are pretty common with the Maico crowd.
Mike
The amount of shock they absorb is really impressive, my first 3 enduro's after "healing" were really bad - I could only ride 10~ miles without stopping 5-10 minutes(race lost!!), I bought the flexx bars($400~ ouch!) and I could ride 35~ miles the first enduro - MUCH improved! For me the bars are revolutionary, almost like going from 4" of travel to 10". In the end the bars are VERY cheap when I consider what they do for me! Thanks to them I won my class for the year so they do work if you have upper body problems.
  • Similar Content
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By Dean.b
      Long story short I bought this 2011 WR300. The thing is mint, looks brand spanking new. The thing ran like a top, but only had one problem, a low idle. I was to lazy to fix it and just dealt with the fact that I always needed to keep a little bit on the throttle. My third ride on it, I took it to the florence dunes and the top end burnt up. I have just finished fixing it and all I need to do is break it in. I need to adjust the idle first though, and don't know if I'll have the idle too high until it starts. I don't want to hurt the motor on a fresh rebuild and want some opinions on what to do. Do you think it will be fine? How many turns out should I set the carb just to be safe?
      Any response helps
      -Dean
    • By dorilabo
      #Husqvarna
      #CR125
      #2-Stroke
      #Maintenance
      #Advice
    • By motoxtremist
      Just bought a used 2017 Husqvarna FC450. It's my 1st EFI bike so I'm hoping someone can help me out with this issue.
      After starting the bike cold and idling for about a minute or two, it blows a puff of blue smoke from the exhaust pipe if I roll the throttle. It also does this if I stop to talk to a riding buddy on a trail or on the side of the track, let it idle, and then start out on track again. After revving it once the blue smoke is gone but riding buds have told me they smell and occasionally see a puff of blue smoke when following me - not a constant stream just a puff and then it's gone for a while. I'm talking to myself over trying to locate the cause of this as a leak-down test shows no issue.
      Bike history
      Bought used with 70 hours on it.
      Original owner had an FMF header and tailpipe on it which he kept. He sold it to me with the stock pipe. He never had it remapped for the FMF pipe
      Started it's life in Atlanta GA
      Now mostly ridden at sea level
      He told me he used mineral-based 10w-40 Yamalube oil. The manual calls for 10w-50 Ester-based synthetic - which the bike is now running.
      This is what I've tried so far:
      Leak-down test produced only a 3-5% loss.
      No bubbles in the coolant with the cap off
      No air leak at the exhaust pipe
      No leak at intake
      Barely, barely noticeable hiss when I remove the oil fill cap - but again not enough to lose any more than 5% pressure during the leak-down test.
      Wouldn't matter but checked the valve clearances while the valve cover was off. They were in spec.
      No loss of power
      No milky engine oil from a coolant leak
      No loss of engine oil as seen at the engine oil level window - never needed to add oil between changes
      Talked to someone who builds motors for a living and he said "all KTM/Husqvarna's do it especially when cold because the EFI delivers more fuel on startup as opposed to running at operating temperature". I guess I can see that but why does the bike blow blue smoke at operating temperature then if I pull off the trail or track for 1 minute to ask one of my riding buds something? I'm not letting it idle for minutes at a time. 1-2 minutes tops. Is this just normal for KTM/Husqvarna/4-stoke racing bikes?? Any help would be greatly appreciated!  Former bikes where 2-strokes (CR250, RM125) and a 1993 DR350 which I could've let idle for 20 minutes an not seen blue smoke - but that was a carbed bike. I've always known if a 4-stroke is smoking blue it's burning oil and you shouldn't keep riding it. So I'm a bit concerned about whipping it around the track or taking it out a few miles on trails.
    • By MotoXRacer_19
      As the title suggests, I've been debating the idea of throwing in a high compression piston. It will bump the compression in my 2014 KTM 350 XC-F from 13.5:1 to 14:1. First and foremost my main question is, because I live under 1000 ft and usually run 97 octane REC gas, will I have to change the fuel I run or not? Also, will I have to change out the cams to aftermarket and re-time the whole motor and ignition? I guess I really don't know what to expect so any advice will definitely help! Attached below is a photo of the bike I plan on putting it in.
