Throttle position sensor
I'm a fool and took the tps off the carb on my 08. Now I need help adjusting it... it didnt have the paint on it showing where it should be so how do i know where to put it back to?
Couple methods. Easiest is measuring the voltage between the yel and blk wires while it warmed up and idle speed set. .58-.78volt
The other is using resistance, easy but a little more complicated.
Working with the 3 wires to the tps you need to take two readings and do some math. record ohms for blue- black and yellow- black.
the blue- black reading multiplied by .13 to .15 (hi low range) should equal your yellow -black reading. If not adjust till it falls into range.
