Ignition Relocation?
I just got my bike back after being hit by a backing up car and being worked on per insurance at my local shop I went from a stock upper triple and bars to a Scotts triple and Pro Taper bars and in doing so they had to relocate my ignition. In the pic I have attached you can see it's in what I think is a crappy spot so, what I want to know is, has anybody relocated their ignition besides where mine now resides and if so where?
Thank You,
Bob.
Sorry forgot the pic.
Still no pic .
Here's where I put mine. With no pic, it's hard to see where they put yours.
So I've tried to post a pic but have been unsuccessful. I see you are running a Zeta clamp were your bolts recessed allen heads and you just swapped the bolts? Also I see you have no blinker did you have to remove it to mount the ignition? I am running a Scotts triple my bolts are recessed allen heads so I'm guessing I could swap them out to a bolt with a head that will hold the ignition. At the shop they mounted my ignition on the left side of the speed o standing upward and it is bolted to the clamp so it's not cosmetically pleasing.
Bob.
Hi Desert, :busted:
Just stick your ignition switch on the side like Iron did.
I put mine on the left because I'm left handed... :moon:
It'll leave your top deck totally uncluttered...
Take Care,
Greg
Bob.
I agree, thats a pretty unsightly place to put the ignition switch. Fortunately, relocating the switch to another location that is more agreeable to you is just about as simple a fix/mod as you'll find. Just unbolt the bracket and move it to your preferred spot. :busted:
Whats the benefit of changing your triple clamp?
The Zeta has a larger fork leg clamping area. It also offers different risers so you can custom tune the height of your bars. The same risers also have 8 different forward/back positions on the tree. It really helped me get my bars into the right position.
Bolts were not recessed. I went with the Zeta hand guards that have the LED flashers in them so I ditched the oem flashers and freed up the spot. The Zeta triple also came with two different bolt sets for the bar clamps. 1 set was recessed allan type, the other was not recessed so you could mount the ignition bracket on top of the bar clamps. I didn't want the ignition up to so I moved it where I thought it felt good.
2763141209_6fba00bb69.jpg?v=0
We cleaned up the bracket since this pic:thumbsup:
Hey Bob,
Maybe you could just bend your bracket so the switch points at you like this.
Pauli
What does the bike feel like with clip-ons?
Here is another option between the fork tube and frame below the top tree clamp. Use one of the threaded holes in the back of the tree clamp and bend the bracket to fit.
Hi fish, :moon:
Feels great! :busted:
The alloy racing bars are lightweight, low, narrow, and tucked in...
...and with a maximum width of only 28 inches, they make lanesplitting as easy as a sportbike. The bike has a real positive feel to the steering with the little stubby bars clamped directly onto the fork tubes.
I installed the bars upside down and on opposite sides so that they would mimic the same angle and aspect as the stock dirt bars.
They also allowed unrestricted lowering of the front forks to match the link lowered rear end.
As far as I know, I'm the only who has done this mod.
Take Care,
Greg
looking good im going to do it to
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
