Help on CR250R springs
I am helping out a friend with his suspension.
He has a 2002 CR250R.
He races east coast hare scrambles and enduros.
He weighs approx 225 with gear.
He is a fast Super Senior B class champ.
The shock and forks have been revalved, but he needs the proper springs for his weight. I helped him get his race sag for the shock but had to use too much preload to obtain the proper race sag. I didn't even bother with the static sag, since I had to crank so much preload into the spring to even get the race sag close.
I am not familiar with current Honda spring specs since I have been on a KTM for the last several years.
I looked on the Race Tech sight to get an idea of what springs he would need.
If someone experienced in Honda suspension could offer some info, I would appreciate it greatly. If you have the stock spring rates and recommended springs, especially for the shock, that would be very helpful.
I understand suspension pretty well, and know that before we can even begin to dial in the suspension (rebound, compression etc...) we have got to get the proper springs. I just haven't had any experience in Asian bike suspension since the early '80s.
The Race Tech site listed this as the spring info:
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.450 kg/mm
Stock Fork Spring Rate: .430 kg/mm (stock)
REAR SHOCK SPRING:
Recommended Rear Shock Spring Rate: 5.20 kg/mm
Stock Shock Spring Rate: 4.9 kg/mm (stock)
I am trying to get his exact normal weight and riding weight so we can have exact info.
Any knowledgeable information and/or comments would be appreciated.
Thanks!
I'm 225 with gear and put .47 up front and a 5.1 in the rear. I have to go about 3/4 of the way down on the threads to get correct sag so I'd say a 5.2 on the rear would be good.
Thanks for the reply. I relay the info to my friend.
  • Similar Content
    • By TheLastByte
      I'm aware the late model 600r's and 650ls are more or less identical, but I wanted to double check before buying.
    • By Chris Kendrix
      New to dirt bike riding and need to service forks and replace fork seals. I have air bleeders buttons on my fork caps. To use the fork cap tool I'll need remove them when I tighten down the cap to the damper assembly. My question is will I have a problem with oil trying to come out the air bleed or air getting in when I have them out reassembling the damper together. Or do I need to buy oem air bleed screws.
      Thanks
    • By 7Fourteen
      Hey, got a 2014 rmz250 with SFF forks, standard springs, 1.0kg/mm in the forks, 5.5 kg/mm in the shock.
      Weighing in at a whole 155lbs without gear and running at an intermediate/B class mid to back pack pace I need this bike to become much more comfortable.
      Race Tech recommends:
      Fork: - 0.88kg/mm
      Shock: -  5.3kg/mm
      Race Tech appears to be a very reputable company and I apologize for questioning their knowledge but I am simply curious. For those who have used their calculator how accurate were their recommended rates.
      Fork: - 0.88kg/mm My main question for the fork is that their recommended rate seems like a drastic jump in fork spring rate. Maybe this is normal because their is only one spring up front?
      shock: - 5.4kg/mm or 5.2kg/mm are the springs available for the shock. Does one spring rate on the shock make that much of a difference?
      Currently with 107mm race sag which is what I find comfortable on this setup, I have 52mm of static sag (Not good, Too stiff) My main question for the shock would be if there is any way to know the amount of change in static sag from one spring rate to another. (5.5 to 5.4.. would that be enough to make the static 35mm. or would a 5.2 be better)
      What is everyone running for spring rate to make the suspension bearable?
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By Nate6283
      Im currently in the process of taking apart my rear shock to replace seals. My problem is there is no valve to release the nitrogen in the shock. Should I just proceed with taking it apart? The manual only talks about disposing the rear shock and says to drill a whole in it, but that would render the shock useless. Anyone have any ideas? Thanks, Nate
