CRF rear fender
Anyone have pics? Done this? I have an XR600R and am looking at my rear fender options. Throw some stuff up for me to check out. Need to be able to mount a plate, brake light, etc to it.
For the CRF fender I was looking at one of the tail deals that you mount under it.
Thanks
Anyone know if the crf450X rear fender will work as well. (with trimming)
I guess i should have specified. Will it work on an 650R? I dont know if the two bikes use similar plastics.
I was going off of the OP's bike which is very similar to the L.
As far as the 650R, I don't see why it couldn't be fitted with some trimming.
Plus they are only about twenty bucks, so an "exploratory surgery" might be called for.:busted:
That is what i was thinking. I busted my tail light awhile ago and the epoxy dripping attempt to fix it so not so hot. That and previous owner cut a hole in the fender to mount so called light.
I have been looking around and crfsonly sells the ufo fender with led light for 42+s&h. Anyone know of any better deals?
Ok, I'll bite. Why do you need to change the rear fender to register it? I'll be the first to post a picture.
Below is my 86 XR600R (taken today), and you can clearly see the license plate bracket and tail light. As far as I know, it is stock. Maybe you could post a pic of what you are working with.
Akarob,
I am in the process of rebuilding my '91 XRR. New plastics, painting the frame, some engine work, making it street legal. It has been plated since I bought it, but has never had all the bs it needs to be legal. I've ridden it for 3 months now with just a brake light, head light, and plate.
Got about 15+" of that white shit on the ground, so I figured what the hell. I am goin to order the Baja Designs DS kit with the tail light/plate holder that mounts under a straight rear fender.
Put the first coat of paint on the frame yesterday after 3 coats of primer. I didn't think it looked too bad....:busted:
before
during
no after pics yet....it's not done yet.
Rustoleum metal primer and rustoleum semi gloss paint. Suppose everyone is going to have a better paint now that I'm about done! :busted:
