AC 10 Tyre Pressures- Quick fix???
Following "Jesus is this normal....." I am settling down with the "riding on marbles" sensation that is riding on Knobblies on the road.
All I can liken it to when not on the power is riding with a buckled front wheel, its not nice. Thanks to all who replied but can anyone recommend what pressure to run on road and dirt to get the max out of the tyres?
Cheers fellas and Happy Christmas!
14 to 18 psi seems good
i ride on the mud and road with 10 front and 10-12 rear thats with 4 mm tubes.
Way, way harder for road use. (Changes from marbles, to ball bearings).
You should have them hard (try 30 psi rear and 25 psi front) for on the road, and drop them on the trails. Measure pressures when the tyre is unused, stone cold. Pressurised air expands when heated, giving a false tyre pressure reading, even when only lukewarm, so go easy when reducing pressure at the trail head.
Don't go below about 20 psi without rimlocks, or the rims can spin in the tyres, ripping the inner tube valve out.
Best advice is from the tyre manufacturer, but experimentation from their guidelines will find the best results for YOUR use on YOUR trails on YOUR bike.
I've ran these tires since I had my z the best compromise on and off road have been 12 to 15 rear and 20 to 25 front period. The front needs higher pressure for the road or it will give you the every other knob wear. The worst I ever seen on a bike that i have owned.
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
