rules against powder coating and other modifications
hey guys. ive got a new 2007 rm85 that is going to be raced in the stock class. it has:
factory connection suspension
renthal bars
graphics
so therefore its "stock"
now my questions are:
can you powdercoat the frame?
what about aftermarket levers?
handle bar modification limitations?
and what can i not in any way shape or form modify?
(based on AMA rules)
Powder-coating is simple dry paint being electrically charged/applied.
*To be eligible for a STOCK CLASS, the following cannot be
changed or modified: Internal engine components, electronics,
frame, carburetor, air box, swing arm, rim size, wheel hubs and
exhaust system. Cylinder re-plating is allowed but must retain the
original manufacturer’s bore. Changes to carburetor jetting is
allowed. Clutch plates, pistons and piston rings may be accessory
items as long as they maintain the stock shape, design and
material of the OEM parts. High compression pistons are not
allowed. All other internal engine components must be stock OEM
parts. Material may be added to the existing frame for strength,
including welding. OEM front and rear suspension can be altered
with internal modifications only. Shock linkage and suspension
spring rates may be changed to any commercially available part.
Any items not listed above may be changed or modified. Violations
of the stock class rules as determined by the protest process or by
the referee of the event will result in a disqualification from the
event. A second violation of the stock class rules will result in a
disqualification from the event and a suspension from AMA
competition for one year. However, if a violation is deemed by the
referee to be cosmetic in nature, with no performance advantage
or willful misconduct involved, he may issue a warning or fine in
lieu of disqualification.
Powder coat away...
