YZ426 Timing Chain Replacement
I finally got around to doing the 450 exhaust cam, and I have a new timing chain to install at the same time.
I'm having trouble removing the timing chain. I have the cams off and I removed the two bolts holding the bottom of the rear chain guide shoe, but I can't get the chain off. The rear chain guide shoe seems to be in the way, and no matter how hard I try I can't remove it.
Take the tensioner out and pull down on the guide and turn it slightly, and it should come right out.
The guide doesn't need to come down or out, although it does need to be unbolted. Lower the chain a little and rotate it 90 degrees on the vertical. As you do this, you can pull the bottom of the chain out around the end of the crank, then lift it out.
I got it loosened enough to get the chain off the back side of the sprocket, but I had some difficulty with the front. The front chain guide is close to the sprocket, but with a little pressure I was able to get more room.
Thanks for all the tips, the job was easier than I thought. I spent more time running to the store to get miscellaneous parts (T30 Torx bit).
  • Similar Content
    • By High On Octane
      Got a break in the weather over the weekend, and was finally able to get out on a track for the first time since October.  I know I suck compared to a lot of guys (and kids for that matter), but I always have a blast twisting a grip and roosting some dirt!  Here's a raw uncut lap around the MX track at IMI Motorsports Complex in Dacono, CO.  Was a fun day despite some wind.  Also, there was a drift car club having a meet on the road course.  So, got to check out some drift car action while we were taking a break.
    • By PFOS58
      Lightly used Clarke Gas Tank (model #11614) for a 2010-13 YZ450F.  Includes cap.  For fuel injected YZ450F, so needs to have fuel pump transferred over.  Rest of stock tank hardware fits perfectly.  2.8 gallon capacity, so great for desert, hare scrambles, or WORCS.  Retails for $240.
      E-mail me with any questions or offers at billsworld@scinternet.net
      Buyer pays shipping from 84726.
    • By faizakhtar125
      Like this comment if you have a YZ. I want to see how many people have YZ's, especially YZ125's
    • By PFOS58
      ProMoto Billet KickIt kickstand for 2010-13 YZ450F.  Model 5006.  Used, but in good shape.  Buyer pays shipping from 84726.  Will take PayPal.
    • By PFOS58
      Used FMF Factory 4.1 Full Exhaust System. Includes slip-on muffler and two piece header.  Includes approved spark arrestor.  No dings or dents.  Fits YZ450F from 2010 to 2013.  You pay shipping from 84726.
