DRZ125 stock needle config
What's the stock setting for this needle? It's got a nylon screw head that doesn't seem to want to turn? Is this adjustable, does it use a standard "clip" in there somewhere? help.
Standard needle doesn't have any adjustment or clip positions. You can pack it up with little .5mm shim washers to make richer or you can buy a TTR needle that has 3 positions. Search my earlier post on Carb rebuild which has pics and instructions from the manual.
