mouth guard anyone?
i have a horrible habit of grinding my teeth in my sleep subconciously, and i saw Ronnie Renner with a mouth guard on the Great Ride Open, and i thought i should look into getting one. I saw them today at wal mart with a 10k dental guarantee for one year haha. does anyone else wear a mouth guard? it would suck going up to a hot chick and smilin with a gnarly grill cause you chipped your teeth casing a big jump :busted:
I wear one for lacrosse you should try it.:busted:
Edit: Personally I do think it would help if you grind your teeth, it will make it so you can't hurt your teeth.
-Jesse
I wore one for years riding track (street). started riding dirt last may and continued but stopped after a few rides because it gets 'sandy'. crashed pretty good and bit my cheeks up to the point of bleeding. wearing it again, dirty as it is.
it would suck going up to a hot chick and smilin with a gnarly grill cause you chipped your teeth casing a big jump :moon:
Naaah!!it's like hockey players you just exsplain about casing the big jump:thumbsup: :busted:
Wait wearing one for your sleep? I had a friend who had the same problem and went to the doctor, he was given a special one to wear while sleeping it looks different then the football ones.
im soposed to wear one for hockey, it just sits in the side of my helmet though, its hard to talk and makes communication hard. ive never worn one for motocross though, but you dont really talk while riding
I wear one and yes it's harder to breath and it gets dirty. But it is good POM. I came up short and bit my lower lip real bad. I have worn one every since. There was a thread on here awhile back and someone mentioned a guard that would let you breath easier, can't think of it's brand name but need to find out by spring.
My grandson races only with a mouth guard. We use the "Brain Pad" is what its called. You have to boil it, then form it to his mouth. We use the Low Pro +
Brain Pad
ocasionally i use a mouth guard simply because some times i clamp down hard when i ride , personally i like wearing one riding . i use a shock absorber one that is supposed to reduce the chance of getting knocked out when your hit in the chin really hard .
i have a friend who knocked his teeth out with a full face helmet on . there fine now but what a pain in the but for a year .
talk to your dentist .. they can make one off of a mold that fits way better then when you buy a cheap one and mold it yourself.
I wear one occasionally. I prefer to not buy the super spendy one because I tend to loose them.
I really like these:
http://www.shockdoctor.com/product/gel-max-mouthguard.aspx
But, they also have different ones of differing grades. They are super comfortable and I've found while riding that I do tend to grit my teeth pretty hard. The mouthguard relieves a lot of the tenseness while riding and also protects my teeth.
Here are a couple more Shock Doctor products:
http://www.shockdoctor.com/product/power-gel-ultra.aspx
Upper and lower guard with breathing hole:
http://www.shockdoctor.com/product/power-double.aspx
FWIW, I've worn mine to sleep a few times as well and have noticed it helped me sleep well and not grind my teeth.
The dentist suggestion isn't a bad one either.
A cheap .97 cent on molded correctly won't interfere with breathing or get dirty. I've worn them for years. HS football. Tae Kwon Do ect... I just buy them at WallyWorld and cut the tether off. I rinse after every ride. If your mouth gets a little dry chew small bit of your favorite gum and add it to the back(Molars).
This is a good thread. I just chipped (2) teeth back in Sept in a dirt nap that could/would have been prevented w/ one of these (not the crash, but the chipped teeth). :busted:
As for going up to some hot chic w/ jacked up teeth, I got that covered w/ these:
I don't get the "not breathing" thing...aren't you suppose to breath through your nose when riding? I do...it helps with fogging the goggles so much. :busted:
picked up this from Target today someone gave me a gift card so i put it to good use, def a nice guard very squishy and comfortable not hard and pointy like the cheap ones
http://www.target.com/gp/detail.html/191-7209013-6059856?ASIN=B001A2X3UQ&AFID=Froogle&LNM=B001A2X3UQ|Franklin_Adult_Gel_Mouthguard_with_Detachable_Strap&ci_src=14110944&ci_sku=B001A2X3UQ&ref=tgt_adv_XSG10001
The not being able to breath is not true. It is just getting used to it. Don't use it long term for sleeping, if it was not made specifically for night use by a Dentist. You could get long term TMJ problems.
  • Similar Content
    • By fudgypup
      Garrett Poucher and Skyler Howes of Garrett Offroad Racing are headed to Dakar!  These US privateers are headed there for their first times but Skyler is fresh off a victory at last week's Baja Rally, won the Sonora Rally in March and this team placed third in the Baja 1000.
      They have a fundraising link set up and could use your help.
      I raced with Garrett at Baja Rally last year and then both of them at Sonora and was honored to pit with them as well.  They're both super guys and work their assess off.  I think they both have good chances of not only finishing the 11 days of Dakar but placing well.
      They're doing some rally training events this Sat, Oct 20 in Santa Clarita, CA and then another Oct 28th in St. George Utah so if you've ever considered learning rally raid navigation, this is your chance!  It's a lot of fun too.  More info on that at the link.
    • By Big64N
      Good condition with a long list of high end upgrade parts.
      Rekluse EXP 3.0 with cover and slave
      EVO- Ellensburg suspension tuning for 6' 200# expert rider
      Fork bleeders
      Trail-tech map switch
      Moose 1-1/8 flex bar
      CYCRA probend bar guards
      SXS skid plate with linkage plate
      Clutch and water pump guards
      Frame guards
      Fastway Evolution III pegs
      SRT Pro Armor radiator and rear rotor guards
      Acerbic Front rotor guard
      TM designs chain guides
      DID race chain
      Renthal sprockets
      Gripper seat
      FMF F-bomb header
      Dirt Tricks timing chain tensioner
      Pro Wheel, wheels
      Tubliss front and rear
      New top end and valve adjustment 60 hours old
      Many more aftermarket parts as well as spare parts and service manuals included in the sale.  Willing to include 4 sets of tires with 80% tread left for full price.
      Great bike with plenty of life left and set up for anything from single track woods to wide open dessert.
      Can hang with any of the 450's but is much easier to handle in the tight woods.
      Priced to sell at $6000.00
      Willing to consider reasonable offers but no trades or carry.
    • By filterx
      34 Days and what ever in Beautiful Chile
      http://www.fim-isde.com/home/
    • By Project57
      So if I can’t buy a used bike from out state looking for anyone that has or knows of a low mileage California 2017 / 2018 Beta 500 RRS?
      Thanks in advance!
    • By Project57
      Looking to buy a used Beta 2017 500 RRS from outside California.  Can I plate (Register with CA DMV) the bike in CA?  If so what is the best way?  Don't have the money to put down for a new bike from a Dealer in CA.  Any help or sugguestions would be appreciated.  Thanks in advance.
