06-09 yz 250 graphics?
i think ive made up my mind on the 2t 4t decision. im going 2t. want to get an 06-09 yz 250. so im putting together next years xmas list and looking at graphics for em, where are they all? is it really that lame that eveything is made and fit for just the 4t's? i mean one industries used to have some sweet choices and now i think there is one, unless u want to turn your yammie into a suzuki!! anyone have a secret brand that has some choices?
factory effects has yz graphics, thought no 09 yet.
Yamaha sells GYTR graphics...look on Yamaha's website under accessories for the YZ250.
factory effects only has the '08 YZ250 graphics todate
follow the links provided by RC ('01 to '08 FX OEM graphics from TT store) and nascarte ('08 FX OEM graphics from factory effects website)
Kai is an amazing kid. She is so cool and so much fun!
The graphics are on page 251 of TT's offroad catalogue. They show the yzf graphics, but they look very similar.
http://shop.thumpertalk.com/catalogs/Tucker_Rocky_Offroad_2008/default.asp?p=251&s=2
02-08 graphics are the same for yzs i believe. I dont think there is any plastic change for 09 either
I dont think we'll see 09 graphics from them. Notice how they have the "125" and "250" printed on them? That would mean two separate sets of graphics for them to deal with. On bikes with limited release......
Design your own graphics - get what you want. :busted:
oh, don't mention it, RC!
i'd kill for those '09 graphics! :busted:
is there such a thing as ordering/ getting OEM graphics from yamaha itself?
try mrcycles.com?
Yes, not a problem at all..if your willing to pay. Yamaha is VERY proud of the oem stickers. The best online price I found on the 08's was 56.00.
thanks, man.
however, yamaha doesn't have the '08 and '09 OEM graphics for the 2 strokes (yet).... all i see are the ones for '03 and '04. am i right, or you have to ring them for a particular order?
thanks, man.
Try a different look up sight. This part is the right 08 graphic 1C3-2174L-00-00 and the left is 1C3-2173L-00-00 The sight I am on shows two part numbers for the set so that would mean 56.13 each! I have not see a sight showing 09 stuff yet.
gracias, man.... gracias.
  • Similar Content
    • By 216AP
      I recently have been wanting to put a led light bar on my yz125 for night riding. I've looked everywhere for wiring diagrams and can't seem to find anything that makes sense to me. I purchased a 45watt stator from electrexworld and I have installed it but I can't figure out how to hook my light bar to it. There are two yellow wires that come out of the plug and I don't know what to do with them. Can anyone help me or provide me with a wiring diagram? PLEASE!
    • By MathiasJK
      Hi guys, I'm new here and bought a have 2001 a month ago and the engine is almost down in pieces, need the flywheel puller that's ordered and the parts needed for the rebound of the engine. I'm also ordering Haynes YZ manual as I think it will be a good buy for me.
      Anyway, the VIN strarts with CE08CE I think... on the back of my cylinder there where some mechanic had written with a marker pen -01 125. It seems like there have been a major failure before, as the head has small dents in it, and the cases are clearly not the same as the one with the VIN is much much smoother in the inlet and crank case.
      Engine VIN is E111E I think, or something very similar to that.
      It has a white Airbox and floating front brake, I've read on other threads here that that was a new thing for -01, is it?
      Fast help would be much appreciated so that I can order parts as soon as possible.
      BTW, here a rebuild with wiseco crank, all seals, new main bearings, new ring and all new  gaskets cost about 500$. Just the crank at Yamaha was 1,200$ at the local Yamaha centre so you all should count yourself as very lucky!
      Thanks for help! I'll post other threads soon as I'm at the beginning is going to post the cases for a smoother flow and have complete HGS system. I really would love to have a 144 but I guess that will cost me insane money as everything is more expensive here, and I also guess sending head n cylinder to the U.S. would cost way to much too... So I'll, be doing what I can on my own and that's the cases for better flow and matchporting it to the cylinder.
      I much appreciate any help! Thanks!
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Allooushh
      Please help! I recently bought a Yz250f and have not been able to start it, it Has spark, but there are many issues with the carby which I wanna rule out before I leap into a rebuild, ( I want to avoid a rebuild if possible as I’m low on cash). The carby at the moment is a complete mess so the usual steps to fixing it might not work. So here’s the deal with the carb:
      - It’s leaking fuel from overflow ( really fast! ) and when I mean really fast, I mean it emptied my fuel tank in 2 mins.
      - It has a slow leak coming from somewhere under the float bowl
      - the air fuel screw is not adjusted correctly
      - I don’t know if the electrics work on it either
      - I don’t even know if it’s shooting fuel into the cylinder or not, as after kicking it a couple times and it’s not starting I remove the spark plug and it’s still dry. ( I tried putting fuel directly into cylinder from the spark plug hole but the bike still wouldn’t start)
      okay so I know it’s a lot but I’m not expecting anyone to answer every single question themselves. If each person could tackle whatever problem they know it would help heaps. Also just want to know what Order to fix things in as I can’t do air fuel until the bike is running and it won’t run unless I stop the leaking and get it to spray fuel into the cylinder. And buying a new carby is not an option ( I’ve got $40 to my name atm). Please help guys thanks.
