Carb experts please look(non jetting) NEED HELP ASAP!
putting my bike together in this cold weather, went to attach my fuel line to my carb, well I think I bent the copper part(# 17) that goes into the top of the float, because its leaking fuel from there when I turn on the fuel...
my questions....
can I fix this, or is it shot? if shot, what exactly do I need to order? #17 only or #17 and #2? thanks!!!
CRF450R%5E2002%5ECARBURETOR?$oemlarge$
#17 will get you a new L-fitting and the o-rings (#2). It could be that the o-rings are just shot, or you could have buggered up the L-shaped doodad.
You won't know until you try.
I had to order new o-rings (#2) for my older bike after it had sat for 6 months waiting on a rebuild.
its been sitting a while, maybe the orings are shot... do I just take out that screw on the side and pull it all out?? thanks for the information!
Yeaup, You can just take that locating screw out and it should just all slide out, obviously there will be some resistance due to two O rings on it. Just wiggle back and forth and it should come.
  • Similar Content
    • By GarrettSG
      I need recommendations on Honda dealers with good Mechanics in Western Washington. I am in Puyallup but will drive for peace of mind. I have never had a dealer do major work on any of my dirt bikes. But long story short I am on a 15 CRF450R and it needs the 5th gear recall done. Any and all info is much appreciated!
    • By jakebarritt
      I have a 2005 CRF450R with a Trail Tech fan kit installed. I need a little bit larger tank and would like to know if anyone has an aftermarket tank that fits with the fan kit.
      I dont need a monster 4 gallon, just maybe a 2.4 or 2.7 from IMS would do fine.  I talked with both the tank vendor and Trail Tech and neither could give me any answers.
      Thanks guys.
      Jake
      Minden, NV
    • By NickC18
      So I emailed Factory Connection today to see what spring rate I need for the rear as I’m about 6’2” 220 lbs without gear. I also asked for a baseline front fork PSI to start at. This is what I received:
      Nicholas,
      The spring series we made for your bike is limited when it comes to larger/stiffer rates.
      The spring rate you need is 5.9/6.0 range. We don’t sell that over the counter as it requires special installation process.  So we can’t sell the spring “over the counter”.  It would have to be installed at our shop.
      Fork PSI I would recommend:
      Inner 160 psi
      Outer 11 psi
      Balance 160 psi
      Are they blowing smoke up my ass? What kind of ‘special installation’ could a spring take? I’ve changed and removed them before but not on a 16’ CRF before.
      Also, aren’t those psi settings for the Kawasaki KYB? I don’t think the psf2 have inner/outer/balance do they? Maybe he was having a bad day...or maybe I’m an idiot. FC’s website list there spring as ALS-0059. Can I not just order this spring and install it to set my sag correctly? Help?
    • By johnsbikerepairs
      hi, i have a crf450R 2009, having difficulty setting the idle knob to factory setting.  Having problems interpreting manual Japaneses interpretation.  Can anyone out there assist with the correct factory setting and how i can manually do the setting ie how many clicks out or in etc...   would appreciate any assistance
    • By Baja Designs
      Hello CRF450R Owners,
      Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the CRF450R and we receive emails daily regarding the best inexpensive light setup or purchasing the B1K setup ran by Ox Motorsports.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments CRF450R related!
      www.bajadesigns.com
