KX100 big bore 107
check for clearance but on my bike(bored 100) my engine builder shaved the valve
I read on another site that the 100 is already over square and that the bigger piston puts more stress on the crank. I was just thinking that more cc's would help out my son offroad wise. More torqe, but since its already a big bored 85 maybe I should just redo it stock.
I am in the process of doing my sons into a 107as well. And the answer to the PV Q, is yes, The PV only sits about 1.5-2mm from the cylinder wall, stock. Going to a 54.5mm bore will definately put the PV in the bore.
If your worried about stress on the crank and you're having the bottom end rebuilt, Get a Hotrods assembly = no worries.
Don't forget to jet for it too. You run it lean??? and kaboom!
