2003 KX250 Ball park jetting????
I got a 2003 KX 250 and so far it dosn't seem to want to idle. I starts up first or second kick cold and goes good with the choke on but its deffinatly running rich. The plug is oily and black sooty looking. The jets are a 160 needle and 48 main jet (or did I get those backwards ?). I dont know where the needle is set yet or the fuel screw.
Anyways I need ball park figures for running in sea level in california between 40 and 50 degrees and running 40:1 mix. Thanks!
Have you tried adjusting your airscrew out and see if it improves(make sure you turn it in until lightly seated and count the turns so you know where your baseline setting was at), if it gets better the more you turn it out and you end up at more than 21/2turns out you need a smaller pilot jet
If the bike is in good mechancal condition(good topend, reeds, etc) if its worn you'll be chasing your tail as the worn motor will constantly be changeing
This is stock KX250 165main, 52pilot, NAFH jet needle on the 2ND clip position, airscrew 2 turns out
This is Pro Circuit's recommended jetting 162main, 50pilot, NAFGjet needle on the 2NDclip position airscrew 1 1/2 turns out
i think pro circui suggest for their factory racers
go 158 main and 45 pilot on 2nd clip.
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
