Rear Tire Size
I am going to replace the rear tire for a Kenda 760 and the stocker is a 120/90-18 deathwing. Will a 120/100-18 fit ok?
Yes, the second number is just the width and you can fit a little wider tire on okay. I believe I have the same numbers, just with a k270.
Either way it will fit. This tire is a 110/100-18. I replaced it with a 150/90-18. Both fit great.
The 1st # is the tire width.
The 2nd # is the height (ratio).
The 120/100x18 is "taller" than a 120/90x18.
The same holds true for auto tire sizes...
A 70 or 80 series tire will be taller than a 50 or 60 series.
265/70x16 (taller) vs. 265/60x16 (shorter) profile
Correct.
I run a 140/80-18....140 wide, 112mm tall which is only a tiny bit taller than the stock 120/90 which is 108mm tall. I like the 140 in the mud and trails.
That 150 will eat the hell out of your gearing tho compared to the 110/100. Did you change gearing to compensate?
Remember that these numbers are often more a guide than an actually mesurement.. 2 different makes/model of tyre with the same numbers will probably be different sizes and shapes.
Size and profile vary with the tyre application. Tyre manufactures make them for an intended bike or purpose. Deathwings are a road biasd tyre, the 760 aren't so the sizes have little relivance to each other..
Rick68fl, can I ask why you used such a large rear tyre???
Yeah, I had already changed to 14-47 sprockets. I had it out over the weekend with the new tires and it worked great!
I bought a Teraflex. Almost all of my riding is in deep sand and super soft stuff. I had been wanting to try out the teraflex for a while and finally went for it.
http://www.mandhtires.com/sc_images/products/276_large_image.gif
Nice! :busted:
Makes sense.. When I saw your pic of the bike on sand that had crossed my mined.. We don't have alot of sand over here, especially near me..
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
