[[Template core/global/plugins/realFaviconGenerator does not exist. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] Jump to content
lorettas question
Im having trouble finding out whether or not asv unbreakable clutch and brake levers are allowed in stock classes for loretta lynns qualifiers? im sure someone on here knows. thanks
From the AMA Rulebook:
To be eligible for a STOCK CLASS, the following cannot be changed or modified: Internal engine components, electronics, frame, carburetor, air box, swing arm, rim size, wheel hubs and exhaust system. Cylinder re-plating is allowed but must retain the original manufacturer's bore. Changes to carburetor jetting are allowed. Clutch plates, pistons and piston rings may be accessory items so long as they maintain the stock shape, design and material of the OEM parts. High compression pistons are not allowed. All other internal engine components must be stock OEM parts. Material may be added to the existing frame for strength, including welding. OEM front and rear suspension can be altered with internal modifications only. Shock linkage and suspension spring rates may be changed to any commercially available part. Any items not listed above may be changed or modified. Violations of the stock class rules as determined by the protest process or by the referee of the event will result in a disqualification from the class, or at the Qualifier level, assignment to the appropriate class. A second violation will result in a disqualification from the class and a suspension from AMA competition for one year. However, if a violation is deemed by the referee to be cosmetic in nature, with no performance advantage or willful misconduct involved, he may issue a warning or fine in lieu of disqualification.
In addition to the above AMA Stock Rule, the following apply to the Stock classes for the AMA Amateur National Motocross Program:
Parts/components that may be replaced or added include but are not limited to: fuel filters, air filters, gas line, handlebars, crossbar pads, non-metal open ended hand guards, serrated foot pegs, lower fork leg protectors, spokes and nipples, decals, spark plugs, spark plug caps, sprockets, handlebar mounts, seat covers, triple clamps.
The kill switch on all 51cc automatic machines must be stock and fully functioning.
Class 18: Oil injection systems must be present and fully functioning. Only oil may be put in the reservoir. Pre mix gasoline is not allowed in the oil injection system.
Removal of gaskets, O-rings or other components is NOT allowed. Port cleanup is NOT allowed.
Aftermarket front fork hole shot devices are NOT permitted.
Metal hand guards are NOT permitted.
Rims can be replaced with OEM or aftermarket rims of the same size and width.
Yea it's fine like everyone else said lol
