250xcfw
Put the JD kit in today, 185 main, stock pilot, red needle, 4th from the top notch, 2 turns out on the fuel screw. Runs real good but slow to idle down and pipe still turns red if left idleing for a few minutes @ around 1k elevation. Fuel screw seems to be in the range described in another post.
Larger pilot?? New bike 08 only about 1 hour on her.
Thanks
Also I put the #60 leak jet and the O ring mod on the accel pump.
I read somewhere that the glowing pipe is because its fairly thin and when no air is flowing across it, it will glow regardless of jetting??
Any help is appreciated, going out this thursday and don't want any "issues"
Thanks
Yup, normal. Don't have the bike sitting around idling, shut it off or ride! :busted:
Yup, normal. Don't have the bike sitting around idling, shut it off or ride! :moon:
Thanks for the info, I will quit worrying and just go ride it N Y's day :busted:
