gas in engine oil
Eddie, do you have any idea why gas would be getting into the engine oil on my 09 crf450? Thanks.
That would tell us that gas is leaking by the needle & seat, two common options;
1: You hauled the bike on trailer or back of a truck with the pet cock turned on, the rough ride bounced the bike enough to allow gas to go past the needle & seat, or
2: A piece of debris in the fuel got between the needle & seat, thus when the engine is not running gas drools thru the carb,
either way gas went into the combustion chamber and runs past the rings thus diluting the oil. If you have hauled the bike with pet cock on change the oil and consider it a learing experiance. This can damage the engine (cam bearing siezure) if run at hi RPM but I suspect if it has not siezed up your OK.
09 crf 450 is fuel injected dave.
to the op,oil smells like gas or has enough to physically make the oil level high?
The 09 crf450 is fuel injected, so it's not needle problem.
Both, smells like gas & has increased the volume.
the only way it is possible is if the injector is leaking when the motor is off.
I thought that to. Should be fixed next week, i'll let you know what the problen was.
What did you find out ?
mxchip, did you ever find out what the problem was with you bike? I am smelling gas in the oil as well on my '09. It has nine hours on it and I just took it into the dealer because the decomp. pin broke and I also told them about the gas in the oil.
Eddie, are you finding the gas smell in the oil of your new bikes? Could this be a leaky injector? I am sure confused. If so, should you change your oil after every ride because the gas will be eating the oil? Thanks.
nope,no issue on ours.
i talked to the OP in the phone.i belive hes having a oil transfer issue from the trans.not fuel.
the oil smelling like fuel isnt a big a by product of combustion.
Honda said they did'nt know what would cause the gas to be in the engine oil,so they told me to ride it. raced the bike last weekend without any problems. Also did not have any oil transfer from the trans to the engine side.
Dave-Eddie, My 07 250 is having this problem, Is it safe to assume the needle you are refering to is the main jet needle? Since I have noticed this I have been deligent to not haul with the pet cock open. So the dirty needle/seat would seem to be my problem. I guess I need to break the carb down?
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
