My TTR 125 Conversion
Inspired by the TT forum I fixed a RM85 fork in my sons TTR.
The rear conversion to a YZ shok is not done jet. I only lowered the stock shock.
Anyhow I considere the biks rear to be a little too high, isnt it?
second pic shows the fork a little higher:
The TTR is a great bike!:busted:
Try photo bucket for the pics, that link doesn't work.
thanks!:busted:
Nearly the same things are necessary like the yz forks.
The RM fork is fully adjustable.
The most common method is to drill a mounting hole about 1" lower in the upper shock mount bracket.
-Kerry
Anyone have any pics of this?
look at the pic : You see the stock hole above the drilledand used one!
I did nothing to the rear of my daughters TTr, sits level with stock rear and yz85 forks .
garage.php?do=viewattachment&attachmentid=54829
I think, it looks better with stock rear!
Is handling the same as stock or better or worse?
I notice your daughters forks are slid up in the clamps pretty far. I think this is good. You can run it like you are for shorter riders or slide the forks down and raise the rear up for taller riders.
