ttr 125 shock spring
i got bbr fork and shock springs for Christmas. i put the fork springs on but i was wondering if i could put the shock spring on with out a spring compressor?
You can do it without a compresser. The spring is short enough.
what do i do? do i adjust the the preload ring until it is loose on the shock and then take it apart?
You are correct. When it get loose enough the bottom washer will slide off.
my bike is at my friends house now so i cant go do it but does it have a slit in it to slide it off with out dissembling the shock?
Yes it does.
