2007 Honda CRF250R factory main jet
I recently purchased a 2007 Honda CRF250R. It was "popping" or "backfiring", and I was told that the bike had been run in Colorado the week before and had a new main jet put in it for the high alltitude. I'm from oklahoma, so I went to Honda dealership and asked for a factory stock main jet, they provided me with a 160 main jet. When I went to replace the main jet, I discovered that it was a 172 main jet. Does anyone know what the main or stock jet is for a 2007 Honda CRF250R? From what I can find the factory stock jet should be a 175 but Iam not sure. Also the bike is very hard to start and I dont know why.
main jet has nothing to do with what happens when the throttle is closed.
if its hard to start you need to check the valves.
i think stock was 172.
Thank you for replying. I'm new to this and have little or no mechanical knowledge. Would the valves be making the "popping" noise when I release the throttle? Also, the "popping" noise seems to diminish after about 5 minutes of running when the 160 main jet was installed. Would running the 160 main jet be harmfull to the engine? What do I need to tell my mechanic to check?
he needs to check the valve clearance and make sure the pilot jet and pilot circuit passages are clear.
Thanks Eddie, I've owned the bike for a week now, and plan on having it serviced by Honda. Besides what you have already said to have the mechanic look at, is there anything else that you would suggest having a look at on a used bike. My goal is good bike that runs will and is mechanically sound. I'm 38 and have no plans on racing and no plans on boosting performance.
NCYR #4, 160 mj, 40 pj, 70 leak, 2 1/4 fs - '04
NCYQ #3, 172 mj, 42 pj, 70 leak, 1 3/4 fs - '05
NHFS #3, 172 mj, 40 pj, 55 leak, 1 3/4 fs - '06
NKBT #3, 175 mj, 42 pj, 70 leak, 2 1/4 fs - '07
NMGU #3, 188 mj, 42 pj, 70 leak, 1 7/8 fs - '08
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Doukis1
      New spark plug, new air filter. Went for a ride and all was good. Hadn't run it in a week and a half. Now it won't start. Getting spark. The plug is dry. Is it possible I over oiled the filter and it has somehow gummed up the carb/ float? Thanks
    • By mbennett95
      My 01' yz125 seems to be requiring a large amount of throttle to get off the line. I've ridden plenty of properly jetted 125's and none required quite so much throttle work from a dead stop. Even slipping the clutch it wont get going without a pretty healthy amount of throttle. Thinking it just needs a clutch rebuild kit and maybe a basket. Any info appreciated!
      If it helps any here is what it has done.
      FMF Fatty, VForce 3 reeds, and an iridium plug.
    • By Sam W.
      Hey all, I just bought a street legal 2005 WR250F. Took it out once three weeks ago. Did about 60 miles on the dirt and 15 on the road, bike ran great. I took it out this past Sunday and was about 75 miles into my ride when the battery died. The battery is cheap, but it is brand new and was on a battery maintainer the whole time while it sat in the garage. I kick started it, and it fired right up. I was on the road for about 5-10 miles in fifth gear when I felt the bike slow down a little bit, and I noticed the sound coming from the bike sounded a bit deeper than usual. About a half mile later the bike started to bog down like it was out of gas. I filled the tank back up and experienced the same problem. The bike began to bog down, then puttered out like it was out of gas. Eventually the battery completely died and I was not even able to kick start it. I trailored it home, hooked it up to the maintainer, waited a couple hours, and the bike fired right up with the electric starter and the choke out. However, it was still puttering a lot when it was idling at this time. If anyone knows whats up, I would appreciate any and all help. Thank you. #Yamaha#wr250f
    • By Ndh87
      I’ve got an old barn find ‘83 CR80R that needs either a new carb or a rebuild kit. I haven’t been able to find either anywhere.
      Does anyone know where I can find either?
      housing, bowl and all the hard parts seem fine, if I can find a rebuild kit with a new float I think I’ll be ok. Right now it runs but only when I leave the choke on, smokes heavily and likes to bog down on takeoff
