V-Force Reeds
I'm still somewhat new to 2-strokes so please forgive my ignorance of simple matters. I bought a 2001 YZ125 and the PO had installed V-Force reeds. I noticed the intake boot is cracked so, is the OEM intake boot used with V-Force reeds or is a V-Force boot required?
v force uses the stock boot, the Boyesen rad valve comes with its own
Those boots have a tendency to show surface cracks that are not all the way through. Spray some starting fluid on the boot while the bike is running. If the R.P.M.s increase then it is likely the boot is leaking. If you don't notice an increase in R.P.M.'s then I would not worry about it right away. You still have some time left on it.
Thanks for the replies. I noticed the crack on the inside of the boot after removing the carb for cleaning. I will inspect it further when I get the chance.
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
