250x better skid plate?
The Hyde plate is what I run. It is quieter than aluminum and easy to take off for oil changes (even with the hole changing the oil and filter is messy, IMO). The one you listed is better than nothing, but a waste of cash unless you add better guards if you ride in rocks. I used one of those WC plates with the stock guards and busted my engine side cover. I believe WC makes a full coverage plate too but it is pricey. http://www.hyderacing.com/store/dirtbike/honda/crf_250.htm
I've been running the WC plate like in your photo for a couple of years now with no problems.
+1 on the Hyde Skid Plate. Like its lightness and ease of removal.
Flatland is a great company, and their aluminum plate is definitely good value and should take care of most riders. After ~100 hours mine was pretty well toast, and not worth welding. My CRF was lowered 2", which certainly didn't help.
If you ride in brutal rocks, the $185 works connection heavy duty plate is the best I've seen.
I've use the DeVol aluminum plate for 4 years and it does a decent job of protecting the engine cases and side covers, but is a bit of a pain going on. It has welded-on wings similiar to the Flatland one pictured above, so you can ditch the stock plastic pieces. Cost is in the $80-$90 range.
The pic you posted is a "glide" plate...generally considered adequate for MX. There are many skid plates that offer full protection for offroad.The "skid plates" generally have the wings welded on or are one piece. Works Connection is definitely the beefiest, but also the priciest and heaviest. I have been running the Devol for a year with no problems...Where I ride is not rocky though.
+3 on the Hyde. It doesn't make the engine bay noisier like aluminum and doesn't affect the frame flex. Honestly, I don't know why someone didn't think of this sooner...............
+4 on the Hyde ... have bashed and crashed the same one for over two years .. it looks like a train wreck now but is still in one piece and still doing its job ...
AH, a glide plate....I think that is more of what I had in mind. I didn't realize the difference at first....so thanks for all the replies.
I won't be doing much rock crawling, if any at all. Mostly will be doing MX and easy to moderate trails with the family.
The glide plate is probably a perfect fit for my anticipated needs....but I'm going to take a look at the Hyde before making a final decision.
I got an carbon fiber skid plate from e-line . Its pretty much indestructable. Its got a kevlar layer sandwitched between carbon fiber. Its quiet,its tough as nails and doesn't bend ,or dent or throw off the flex character of your frame. Its slightly flexable ,which is great for your frame flexing. Mine's been on for three years now and looks great. probably good for another couple of years. I ride rocky mountain terrain ...lots flying up at this thing. I find the alum ones bend and are hard to install after removal ..specially if its been dented and bent up a bit.
I put the utah sports cycle on my daughter's 250X and it fit great and is extremely tough! Do yourself a favor and add some foam tape on the frame rails when installing to reduce the engine noise that increases when adding a skid plate (and helps protect the aluminum frame rails as well). BTW- the thickness is slightly thinner (0.162) then the enduro engineering plates on both of my KTMs (0.186) (not sure what thickness the other makes are) but it hasn't bent or dented so looks to be a bit cheaper to buy and no loss in protection.
Utah Sport Cycle
I just bought the Devol and really liked the look of it. After installation, I really liked it. We put the WC on my boys 150R, but it doesn't have the protection of the Devol. I like the Utah plate also. Look at them and see which you like best. The Devol had more air slots, if it matters.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
