1994 xr100 suspension upgrade questions
I was told that the cr80 suspension is a direct swap for the xr100. Can anyone verify this? What years cr80 are swapable. Also what all is interchangable? Forks? Trailing arm? What about plastics and such. Any help would be much appriciated. thanks
The only direct fit I believe is 1983-1984 CR80 forks. You can use any year of CR80/85 forks, but you will have to have a stem made for it. None of the swingarms are a direct fit.
