1991 kdx200 engine problems!!!!
hi i have a 1991 kdx 200 i recently picked up from my dads house. it used to run fine but since ive gotten it back it hasnt ran right. it smokes like a @#%$ and doesnt idle. i installed a brand new carb with no effect, tried all different kinds of jets to no avail, cleaned the pipe and silencer and changed the plug. nothing seems to make it run any better. it has no response to air/fuel mix screw adjustments or idle screw adjustments. the only thing i did with some noticeable change was i took off the choke completely(which created a massive vacuum leak) and it ran a lot better... i have hit a troubleshooting brick wall and NEED HELP! :busted:
Take off the exhaust and look at the piston/ring. If they are seized, that can cause your problem. If the are ok, check for transmission oil getting past the crank seal by keeping an eye on oil level at window to see if it drops. Could be coil/ignition/plug cap or stator also. You may have to ck all of these. Good luck.
thanks, i bought a fresh top end but havent put it in yet. i know its not seized because the bike does run, but not very well. i also recently replaced the crankshaft seal on the flywheel side. it was leaking before and the bike ran ok when it was leaking. i also was thinking it had to do with the ignition circut.. is there a way to test the components with a multimeter to see if theyre all ok? i really appreciate all the help
check your pm's. Just sent you one!
thanx. it said in the maual to check the coil with an ohmeter. i got a good reading on the secondary side but not the primary side. it read 0 ohms. so do i need to replace the coil?
does anyone have any other suggestions???
doesnt sound like an ignition issue. what kind of meter are you using? the primary will be so close to 0 ohms that a lower quality meter or an analog meter will read 0. if you make a huge vacuum leak and it runs better then it is almost certainly a fuel air ratio problem. are you sure the float isnt stuck open? is the top end toast? do a comp test. do the reeds exist, and are they in good shape? what do you mean by new carb? no offense but are you sure you installed the seal correctly?
These bikes chew power valves , maybe thier stuck wide open , check compression, float in carb , re build your old carb and try that if still not getting anywhere
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
