Cleaning engine block , like professional. a question
This thing fairly new to me, heard from the great thumpertalk forum :busted: about blasting. What set do i need ? the very basic /cheap one..
Are you talking about sand blasting a bike engine case?
If so, the case and covers have some type of clear coating on them. If you sandblast them down to raw aluminum it would initially look good, but corrosion could be a problem. I use SOS pads or some fine steel wool with soapy water to clean them up.
