1996 yz250?
Hey guys I was just offered a 96 yz250 for 500 bucks..... My cousin owns the bike and right know its seized up. He said its bored out to a 280 and has a brand new clutch installed. Do you guys think this is would be a good buy?
You got to think about how much money your going to put in to it. You might run into more problems also.It may need more than a lower end, the cylinder might need to get replated if its in bad shape, also a piston if its in bad shape. Is it worth it to you?
I'm with crider400.
How much of the work can you do yourself? If the bike looks to be in great shape and you can rebuild the engine, then it's probably worth it. If it's a rat and you'll be paying someone to fix everything for ya, then it's throwing money down the toilet.
I own a 1996 YZ250 (since new), so those bikes are close to my heart. :moon:
1996 was the first year of the 'modern' YZs, so they have good suspension and handle much better than the older bikes, IMHO.
If you think you can get it up to snuff for less than $250, then the $500 purchase price seems like decent deal.
The '96 and '97 YZs are pretty solid bikes -- almost overbuilt. I bet one with a big bore would be a riot!
But listen to what crider400 and adam728 said, and try to figure your total investment before diving in. :busted:
Are you riding woods or MX? If woods then you need at least a 10 oz Flywheel weight and a FMF Fatty pipe. Thats another $200-300 plus a set of barkbusters $50. No one made or makes a gnarly pipe for a 96 but the fatty works better.
My 96 with those mods is a great woods bike. I wold say it is worth $300-350 like it is.
yeah the bike is in pretty good shape. Putting some money into the bike is okay with me. I am riding mx.
  • Similar Content
    • By faizakhtar125
      Hey guys I found a bike for a really cheap price. I figured out the total cost, and if I sell it I can make $850 in profit. It is a 2002 Yamaha YZ250F. He said the bike starts but then dies. I am not sure what the problem is. Is it needing a carburetor clean up? What would be the total cost to fix it?
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
    • By fiat2nv
      Hi all, First post here. I need some help.
      Ive just bought an 05 yz 125 for a good price but it needs some work. One of the forks has some pretty severe pitting of the chrome on the stanchion towards the bottom near the brake caliper mount.
      Ive found a pair of good condition forks from an 04 yz250 for a very good price, from the research ive done its seems that both the 04 & 05 forks are 48mm but are different, with the 05 fork regarded as being better than the 04, but not as good as the 06 + sss forks.
      Im looking for the cheapest way to get me riding, Will I be able to make the 04 forks work with my 05 triple clamps, brakes, wheel, axle, spacers etc? If not does anyone know what hardware id need to make it work?
      Finally, as a last resort, does anyone know if i could swap the stanchion from the 04 fork into my 05 forks?
      Thanks, Andrew
