drz400sm fcr carb jetting???
ok I have a 05 drz400sm and just got a new fcr39mm carb for it . the bike has full yosh, exhaust 3x3 air box modd and a k&n filter what jetting should I use?
Where did the carb came of ?
Is it a mx or a std fcr from a drz-e model ?
the carb is new the person I got it from had 3 of them that he got from a bike shop closing. i would say it is in mx carb,he wasnt sure what bike it was for but I see that the tps is the same as my drz. it has choke but no hot start.
Do you have the right bell for the air boot?
If it is a MX (Box it came in should say) then:
Remove the #100 Slow air jet from the carb mount
EMN needle, clip #3
45 Pilot jet, 2 turns on the fuel screw
160 Main jet
Do the oring mod.
ok I'm haveing a hard time finding the jets and or neddle kit that I was told to use.:excuseme: I looked in The TT store and all they had was the JD kit I found a kit (http://www.dynojet.com/pdf/3111.pdf) but this dosnt contane the parts that I was told to use.... ok dose any one have what I will need to do the jetting for my bike.:smirk:
well after a 5 month breather......
still havent really answered the questions.......
type carb?
removable intake bell?
what jetting is currently in it?
got a pic?
if you have a compatible carb you need this stuff
to make it work.
- 021-216 FCR Adapter 2 3/8", carb to S airboot
- 021-439 Adaptor O-Ring
- 017-262 EMN Needle
- 021-012 Airboot adapter bolts (2)
can get from sudco...
- P/N 13111-29F00 OEM Suzuki E Intake Manifold
- P/N 09402-58208 OEM Suzuki Clamp
- P/N 13685-29F00 OEM Suzuki Vacuum Port Nipple
can order from TT store or stealership
as for the jets, check around the local dealers.
fcr's are on a lot of Mx bikes
