Mikuni HSR pumper - close but no cigar
I'm trying to dial in my Mikuni HSR pumper on my 2000 XR650L. It seems to be running well except for one thing: when I pop the throttle from idle, it hesitates, blows a little black smoke out the exhaust, and has backfired a couple of times.
My engine is stock, smog and snorkel removed, slip-on Pro Circuit T4.
My carb is currently set at:
160 main
22.5 pilot
1 3/4 turns
96 needle, lowered 1 notch
Any suggestions? Thanks!!!
back the pump screw out till it responds clean.you will increasing the gap a bunch.
Thanks, that did it. Now that that's fixed, I have another small problem: at a steady 1/4 throttle, it sputters a lot. Any more than 1/4 throttle, it clears up and runs fine. Any suggestions? Thanks!
go back to the stock needle position.
Works great - runs much better than ever! Thanks for all of your help! You're a GENIUS!!!
