07 Won't Start now - checked valves
I have an 07 CRF150RB that has limited adult riding time on it, maybe 15hrs. The last 2 times I've pulled it out it would not start. Drained gas/carb checked spark and tried again. NO go, not even a hint of starting. Pulled valve cover and took following readings:
Intake Spec .006 +/- .001
Left Intake = .005
Right Intake = .004 (.001 out of spec)
Exhaust Spec .010 +/- .001
Left Exhaust = .008 (.001 out of spec)
Right Exhaust = .009
Would a .001 out of spec intake and exhaust valve create a no start issue with this bike? Pretty bummed they are already out of spec and this bike will not start.
Thanks for any input.
Those clearances are fine. You probably have a plugged pilot jet. Take it out and replace it with a new 45 jet. Set the fuel screw at two turns out. When starting a cold bike, pull the choke, position the piston at TDC, twist the throttle 2-3 times to prime the engine and kick.
