Chickenhauler
Suzuki 2 Stroke FAQ
This will be a compilation of threads that contain many of the frequently asked questions about the yellow smokers.
TT OEM Parts Fiche (A good source for assembly schematics and parts)
This is just a start, if you know of something that should be added, post up a link to the thread or PM me and I'll get it added to the index. This FAQ will be as good as you guys make, it's your ideas and knowledge.🤣
  • Like 2
It's only going to be as great as you guys make it, I'm just the "secretary" doing the "filing" work, since have owned a grand total of 0 yellow smokers.
There are always questions about "What does this fit?", "Can I use this part?", etc. I find comparing the OEM part numbers for various models very helpful.
How about a link to the TT OEM parts fiche, so people can look up parts and see what goes where, and what fits what?
http://shop.thumpertalk.com/oem.asp
Thank you!
We need to add a good thread about how to rebuild a top end. That question is asked alot around here.
Someone either post one with pics or find one, and I'll add it to the index.
The more pics the better, and if possible, put in torque specs and such.
http://www.youtube.com/profile?user=RockyMountainATVMC&view=videos
Multiple videos about top end, bottom end, clutch, fork seals etc
Suspension setup
1989-1995 specs
Front and rear tires all models: 10-16psi
Transmission oil:
-Rm80 = 550 mL
-Rm 125, 250, Rmx250 = 650mL
Cooling system capacities:
Rm80 = 550 mL
Rm125, 89-90 = 800mL
Rm125, 1991-on = 900mL
Rm250, 89-91 = 850mL
Rm250, 92 = 1100mL
Rm250, 1993-on = 900mL
Rmx250, 89-91 = 850mL
Rmx250, 1992-on = 1100mL
Radiator cap pressure relief = 16psi
Air screw adjustment turns from fully seated (closed):
Rm80, 1989 = 1 3/4
Rm80, 1990-on = 1 1/2
Rm125, 1989 = 1 3/4
Rm125, 90-93 = 1 1/2
Rm125, 1994-on = 2
Rm250, 89-93 = 1 1/2
Rm250, 1994 = 1 3/4
Rm250, 1995 = 1 1/2
Rmx250, 89-91 = 2
Rmx250, 1992 = 1 1/2
Rmx250, 1993-on = 1
Mixing ratios:
Rm80 1989-on = 20:1
Rm125, Rm250, Rmx250
1989-1991 = 20:1
1992-on = 32:1
Torque specs:
Cylinder head nuts:
Rm80, Rm125, Rm250
1989-1992 = 19-22 ft-lb
1993-on = 16.5-20 ft-lb
Cylinder nuts:
Rm80, Rm125 = 16.5-20 ft-lbs
Rm250, Rmx250 = 26-29 ft-lbs
Magneto flywheel rotor nut:
Rm80, Rm125, Rm250 = 22-29 ft-lbs
Rmx250, 89-92 = 22-29 ft-lbs
Rmx250, 1993 = 66-73 ft-lbs
Rmx250, 1994-on = 59 ft-lbs
Clutch sleeve nut:
Rm80 = 51 ft-lbs
Rm125, Rm250, Rmx250 = 66 ft-lbs
Number of clutch plates and discs:
Clutch plates:
Rm80 = 4
Rm125 = 7
Rm250 = 8
Rmx250, 89-91, 1994-on = 7
Rmx250, 92-93 = 8
Friction plates:
Rm80 = 5
Rm125 = 8
Rm250 = 9
Rmx250, 89-91, 1994-on = 8
Rmx250, 92-93 = 9
Fork oil levels:
Rm80 = 359mL
Rm125
89 = 656mL
90 = 452mL
91-92 = 610mL
93 = 650mL
94 = 455mL
95 = 435mL
Rm250
89 = 408mL
90 = 447mL
91 = 619mL
92 = 615mL
93 = 656mL
94 = 460mL
95 = 440mL
Rmx250
89 = 408mL
90 = 452mL
91 = 623mL
92 = 626mL
93-on = 653mL
Carburetor Specs
Rm80 1989 - on
Type: Mikuni
Model
1989-1991 = VM28SS
1992 - on = TM28SS
Identification No. 03B00
Main jet = 210
Main air jet = 2.5mm
Needle jet = p-4
Jet needle = 5DP39-4th
Pilot jet = 30
Float Height = 17.2 + or - 0.5mm
Rm125 1989 - 1992
Type: Mikuni
Model
1989-1991 = VM35SS
1992 - on = VTM35SS
Identification No.
89 = 27C00
90 = 27C10
91 = 27C30
92 = 43D00
Main jet
89 - 91 = 330
92 = 320
Main air jet (1992 only) = 2.5mm
Needle jet = R-1
Jet needle
89-90 = 6AEJ2-65-3rd
91 = 6AEJ2-65-4rd
92 = 6AEJ6-66-3rd
Pilot jet
89-91 = 55
92 = 50
Float Height = 14 + or - 1mm
Rm125 1993-on
Type: Mikuni
Model = NTM36SS
Identification No. = 43D20
Main jet = 360
Needle jet = R-1
Jet needle = 6AEJ0-63-3rd
Pilot jet = 55
Rm250 1989-1992
Type: Mikuni
Model
89-90 = VM38SS
91-92 = NTM38SS
Identification No.
89 = 28C00
90 = 28C10
91 = 28C20
92 = 28C40
Main jet = 370
Needle jet = R-1
Jet needle
89 = 6AEJ1-62-3rd
90 = 6AEJ1-63-3rd
91 = 6AEL1-60-3rd
92 = 6AFL1-60-3rd
Pilot jet
89 = 55
90-91 = 50
92 = 45
Float Height
89-90 = 14 + or - 1mm
91-92 = 16 + or - 1mm
Rm250 1993-on
Type: Mikuni
Model = PJ38
Identification No. = 28E10
Main jet = 180
Jet needle
93 = R1471NS=3rd
94 = R1469MS=2rd
95 = R1470NS=3rd
Slow jet
93 = 45
94-95 = 52
Float Height = 16 + or - 1mm
Rmx250 1989 - 1992
Type: Mikuni
Model
89-90 = VM38SS
91-92 = TM38SS
Identification No.
89 = 05D00
90-92 = 05D40
Main jet = 260
Needle jet = R-1
Jet needle = 6AAY1-67-3rd
Pilot jet = 45
Rmx250 1993-on
Type: Keihin
Model = PJ38
Identification No. = 29E2
Main jet = 200
Slow jet = 60
Jet needle = R147M1L-3rd
Hopefully these specs will come in handy 😛
  • Like 4
Jetting
This is just a start, if you know of something that should be added, post up a link to the thread or PM me and I'll get it added to the index.:excuseme:
Learned a lot about jetting...that information was needed.
Where did you find all of these specs? I just picked up a 2001 RM 80 and I'm looking for the premix ratio. 20:1 seems pretty rich but I'm not that familiar with 2 smokes.
One other question, it has the stock muffler which doesn't have a spark arrestor. What are my options?
Thanks
Thanks
too rich!!! Mix 35-40:1 depending on your atmosphere and riding style
Define average mixture.
People run different mixtures depending on their displacement, jetting capabilities and riding style/terrain.
32:1 I have found to be very capable to lube the top-end but that being said, if I owned an rm80 I would go with the service manual over my own opinion.
Just my opinion :doh:
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
