Aftermarket headlight photos please
Hello folks
Im contemplating changing the headlight on my DRZ i feel its the only part of the bike that could do with changing to make it look more modern/ agressive post up your pics of different headlights to give me a hand
Here is mine! More custom than aftermarket though!:lol:
Check my garage , i have a exc '00-'04 ktm headlight .
Bump! :p
Acerbis Dimension HP
Black Mamba
Acerbis Diamond
Baja Designs 8"
I gotta tell ya...I like Rock Monster's custom setup!
I was all up for upgrading my lighting to HID but after reading the letter of the law I read that unless the unit is E-marked and comes as a complete kit, i.e. lens, reflector... ballast etc it isn't road legal over here. Which doesn't shake me down too much but after riding through Tooting, and Streatham late at night I know why they set that law to be thus. It dazzles all oncoming traffic if fitted incorrectly and is a public nuissance. Nothing more irritating than being blinded when riding.
So yeah, I'm up for an upgrade too but prefferably designed as a full e-marked bit of kit.
Trailtech do a nice bit of kit, I'm just not sure whether it's road legal and going to be dazzling beam of horror for oncomers.
Check out their stuff.
acerbis DHH
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
