04 525 EXC clutch info / advice
I have a 04 525 EXC that is CA. Plated. and I have ridden it twice, and the clutch is slipping. (btw it only has 2000 mikes on it). I have been riding since I was 12, and am 46 now. . . and have NEVER fried a clutch. My last bike was a CA Plated Honda CR500, so I know I ride it a bit like a 2 stroke, but I am not at all abusive to it in any way. . . so. . . :lol:
I am curious what people are using. My local dealer (Z Racing) says use the stock ones, because of the thickness. I know there is Barnett and DP. . . Barnett has been around forever. . . any input would be great.
BTW I ride CA desert mostly. The plate is so I can ride single track in the local mountains. . .
Big Dave
i dont know much about ktm clutches other then there not bad...
i would not put barnet friction plates in unless your sure its not going to drag.
get ktm or ebc
Always best to go with OEM parts. I would buy stock fiber plates, and soak them in engine oil. While the new fiber plates are soaking clean the metal plates with brake cleaner and then buff with fine wet sand paper on a flat surface like a piece of glass. Re-assemble and go ride that thang!!
The first thing you need to do is crack your bleeder to be sure the slave or master is not hanging up, then replace with OEM parts. Like was stated they are good. CJ
I was told they (ktm's) need the correct distance in the clutch pak or there will be issues.
ALSO my metal plates are all glazed, and was the cause of the slipping, so I want to replace them as well.
Very odd, I've had 5 ktm'S and have never replaced a clutch in any of them, what kind of oil are you using? i'd go for the OEM stuff, I ride the crap out of my 04 525 and it still works flawless, just over 200 hours on it.
I know! I have NEVER had to replace a clutch. . . EVER yet in two rides on this bike. (again, I bought it used with only 2000 miles). . . But STILL. . . this isnt the 1st used bike I've had, and I KNOW I didnt slip the clutch THAT much. . .
I will just use the OEM. No one so far has reccomended using a aftermarket one.
the plates are so thin that they can warp. Its common to flat sand them while checking for warps. Only needing to replace the warped ones. Knock the glaze off and ride. There are different thicknesses for the different years so be sure you get the right stuff if buying new.
What oil are you using? If you use an automotive synthetic with frcition modifiers - that will do exactly what you are talking about. I run Mobil 1 synthetic Twin 20-50 (for cycles only) and no problem. The most recent issue of Dirt rider says the plates can "mushroom" (they don't specify the model year) but I don't know if that would cause slipping.
Nobody is reccomending an after market clutch for KTM's because the OEM clutches are that good. They seem to last forever.
Being that this is a used bike, I would think it is something the PO has done to it. Either running automotive oil in it or maybe putting lighter springs (like out of a 250) in the clutch assy. to get an easier lever feel.
I think I would pull the clutch pack and start inspecting. Look for warpage and glazeing.
(what kind of oil am I using) I am using Maxima Synthetic as per recommendations by Z-Racing here in Orange.
HOWEVER. After buttoning it all up, starting it, (couldnt ride because it was 11:30 pm ) I loaded it up, drove out to the dez, and hopped on. Started it, let it warm up, pulled the clutch in, clicked it into gear. The bike clicked into first gear, I let the clutch out. . . then nothing.. The bike didnt move. It was like the clutch was still pulled in.
The ONLY THING I can think of is Z Racing didnt give me enough plates. I didnt count them. . . I assumed it was the correct amount. . . SO, back in the trailer it went.
At least I didnt have to clean it after I got home.
will keep you all updated after I pull it back apart.
Big Dave
Should have 7 friction discs and 8 drive plates.
I'm going to concur with most of the others here who say the OEM clutch is stout. I have 300 hours (12 000 kms) on my 05 525 and I just measured the factory clutch plates. All are very well in spec.
If your clutch was still good before your last two rides, then I'm afraid you might have an issue somewhere that will likely wear out the new clutch if it's not fixed.
Sean :p
I'm sure it may have to do with the slave. because after removing the cover, I noticed the plates were movable within the basket. . . there is a ball within the slave cyl. and its not supposed to come out, but we'll find out tonight
yes there are the proper amount of plates (8 steel - 7 fiber) They are supposed to measure 21.8 - 22 mm overall thickness. . .
thanks all!
its like a mystery!. . . a whodunnit!
Big Dave
also- probably not but - check that you put the clutch springs in right...
wasnt aware there was a wrong and a right. . . they look the same on both ends. . .
but thanks. . . I'll dbl ck that
First check is hand gaurds! If the lever so much as touches the hand gaurd you have trouble!, Next is the link adjustment at the lever, you need to understand how a master cylinder works, lever pushed a link, link pushes the piston, piston is in a cylinder, the cylinder in under the reservour and there is a tiny hole or port from Res to the cylinder. It is abosutly imperitive that the link not hold the piston is too far so the piston covers the hole! If it does it is not going to work right!
Next issue, there where changes inthe clutch in 06, if you mix 06 parts with 05 you can get in trouble, example the push rod is longer in 06!! So has anyone been inside?
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the advrider.com writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
