Alright so I was running my YZ125 today, and I put in a lightly used BR8EG and the white part was golden brown when I put it in, and I rode for about 5 minutes and took it out and It was completely white, there is not oil accumulating around the silencer hole. This seems weird because today it was about 50 degrees, but the other day when it was about 35 to 40 degrees it was running fine and had alot of power. As far as I know I am still running on the stock jetting. This just seems weird to me, any thoughts?
btw: it seemed like it was running fine when i had a br9es and it even had some oil on it.
Yeah, sounds like the bike was running too lean. Maybe dangerously lean at 35-40 degrees.
Well it seemed to me like it was running fine when it was around 35 degrees, it was today when it was about 50 degrees that it seemed like it was running really lean, and what can I do to fix this?
Do not run a 8 series plug in a YZ125 in the cold. Otherwise, this could easily happen to you. :lol:
You need to richen your jetting to reflect what the days weather will be like. Forgoing this step could be costly. :worthy:
What do I need to change on the jetting?
Put a 9 series plug back in. Fiddle with your air screw (turn inwards) to make richer. If not better, get a richer pilot jet followed next by lowering the clip one position on the needle and if your problem is in the upper rev range - go richer on your main jet too.
Way way more detail available here:
why would I have to rejet it richer?
To alleviate the lean condition seen on your plug. If you're too lean with colder than normal air temps (for your jetting range) engine damage may occur.
But why would It run fine at 35 degrees and when its at 50degrees it runs lean? and would sta-bil in the fuel make any difference?
It's running leaner at 50* now because you're running a hotter plug (8 series) than before with your 9 series at 35*. A nine series is a cooler plug. If it burns hotter than what it's designed for in your combustion chamber - it's gonna be lean even though the air temp has risen.
So all I have to really do is just run the 9 plug and it will all be good? Also, I think the bike is probably jetted for warm weather so should I run an 8 then or keep running 9?
^ Run the 9 and jet from there.
Ok, but if it is jetted for warm weather then can i still ride it safely when its kind of cold out?
IMO, if you ride at 50* it won't likely seize with the correct plug (9 series), 32:1, and at least stock jetting values. Below 50* and you need to richen all circuits likely.
What plug do you reccomend for racing?
When I got the bike it had a br8eg plug in it and I rode it in temperatures around 30 degrees and it seemed to run fine, but then I put a 9 in it and rode it on that for a while and it seemed fine and when It was 50 degrees I put a lightly used br8eg in it and it was running lean, I just dont understand it, because I thought that when It was colder is when they run lean, but It ran fine it seemed to me like when it was around 30 degrees.
yeah br8eg is hotter that Br9eg so in warmer temps when running the Br8eg there is more of a chance to seize
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
