countershaft seal?
How hard are these to replace, i have one leaking pretty bad.
Easily done from the "outside". Pry the old one off and replace it.
clean it first, probly has dirt in it. Also re-cup the washer, it needs the tension to seal, and it needs to have a stock sprocket to be sure thickness is correct for the tension on the seal system.
Good point (the stock front sprocket) on RFS engines but not needed on the new 450/505 SXF/XCF engines.:lol:
well i didnt know thatm 07 250xcfw looks the same, but I havent had it apart yet. How are the new ones different?
i have a 06 sxf 250 and if is leaking also where can i find a how to guide
I assumed his bike is an 450 or 505 SXF. Those have had some issues with leaking CS gaskets. You do know how these engines differ from the old RFS , right ??
I haven´t heard about leaking CS gaskets on 250 SXF /XCF´s but that engine hasn´t ,of course , changed much since it was introduced in -05.
I know they are different motors, but I dont think the CS seal system has changed, maybe it has, I havent taken my front sprocket off yey.
The old RFS engine needed the exact OEM front sprocket thickness to press on the CS to prevent leakage.. Not so on RC4 engines. You can use aftermarket sprockets too.
I had not noticed that, so the factory sprocket is thinner? or is it more cup in the washer to allow the thinner aftermarket sprocket to work?
Anyway I have never replaced the seal, I pull the sprocket, clean all debris off with paint brush & brake clean, then pull the inner sleeve out and and clean the inside of the seal with a Q tip. pack the space between the shaft & seal with waterproof wheel bearing grease and push the inner sleeve back in, recup the washer (big socket open end up, washer cup side up on the socket, big ballpeen hammer ball side down into the cut, take another big hammer and hit the ball peen hamer HARD! reassemble with lots of RED loctite on the threads and torque to spec!
  • Similar Content
    • By OffroadMT
      I am purchasing a 2012 KTM 350XCF after wanting one for a year and finally picking one up in December. My question is what are some good things to watch for on this bike as far as initial set up and good Mods to improve bike ? My plan is to add a skid plate, hand guards and muffler with the possibillity of changing the header pipe and a Rekluse EXP would be nice as we ride mostly single track mountain trails with some rocks . Any good thoughts and suggestions would be appretiated
    • By element9
      The story begins with simple installation procedure of a BIG BORE kit that we ordered from USA . The manufacturer (CYLINDER WORKS) and the dealer send us the correct kit and so far so good ! .
      The bike is a KTM 250 sx-f ,2011 model and bellow there are some photos for you, just to see how careful I am throughout the process .
      .. .. .. .. I change the valve seals and the exhaust titanium valves and springs with the PROX steel kit and make a little polishing on the intake and exhaust
      Put the cylinder-piston on and always with guidance from workshop manual and correct clamps...
      Until now we where happy !!! We start the engine ,and everything seems to be ok!
      Began to make the first ride and…… DISASTER !!!
      The engine start bleeding OIL from the hose-tube !!!!!!!!! I thought its normal if it is one-two drops but unfortunately didn’t STOP .
      We did one more ride to see what happens and still BLEEDING. Back to the WORKSHOP.
    • By Dutch84
      I got about 6 months on my 350 xcf-w. I ride a lot of tight, rocky,rutty, slippery single track in South west PA. The only things I've added are suspension, bark busters, skid plate and disc protectors. I purchased a trail tech mapping switch but hesitant to add it as I heard the dealer needs to unlock the ECU and am not sure how much of a benefit it will be. I have a Scott steering dampner I'm going to add. I'm also looking at exhaust options for my riding conditions. What do you guys think about the items listed and what suggestions do you have?
    • By shift1313
      Hey guys, i just picked up a used 2012 ktm 450 sxf to be my supermoto race bike next year. the bike seems pretty much stock but there is a connector on the left side of the steering stem that I am 99% sure couldnt be factory. Its a 4 pin connector, 2 wires in, 2 wires out(to the Estart switch on the bar). On the estart side of the connector there is a small jumper wire in the other 2 spots. I have found lots of info on adding the ignition map switch but i can't find anything about this connector or if it was factory. There is a small coil of wire just before the connector and the connectors appearance makes me think it was some aftermarket or home brew ignition map switch. This is a carb US 450sxf.
    • By riyaadhd
      hi TT users
      i have a flat 11 acre property 20 mins from my house. the property has a pond in the middle of it.
      i am wanting to build an mx track on there, What equipment/excavators will i need to hire. how will i go about constructing the berms, whoops, table tops and jumps. And how can i keep out unwanted riders. How much dirt will i need?
      i would be great if any ones knows track designers and cheap dirt and machine hires. (Dont have much $$ to spend so free or cheap dirt and equipment would be GREAT )
      i am in Brisbane, qld, Australia. Any quarries i can phone to dump free dirt
