Making that Aluminum frame shine...
My '06 250f has hundreds of hours hence wear on the frame. The bike is stripped down to the frame right now so i figured i would clean it up. what product should i use to clean/polish my frame?????
Use some 100 grit sandpaper, sand the frame. Then move to 200 grit, then 400, then 800, then 1200, then 2000.
Spray off all the alumi. dust, then take some Mothers Carnauba Wax and buff the frame lightly. After that take some Meguairs Motorcycle Polish and polish the frame.
holy shitte! thats shiney!
that is beautiful! i particularly like the shiny covers. i would do something like that myself but i wouldn't want all that ally dust getting sucked into my engine. maybe if i stripped her right down to the frame and put the lump in a separate room! that is the coolest thing ive ever seen though!
have you had any issues with your polished frame? do you typically have to rebuff after riding
That 06 above me looks pretty sickk.
And to DirtPipeRider, just take the cover off, polish it, then take a low-PSI air gun and spray all the dust off. To prevent the dust from getting in my ignition and clutch plates, I took a plastic bag and taped it over the gears and clutch plates. It worked pretty well.
If anyone has any questions on the process I used, I know it's posted before, but if you have any specific questions or want some advice, feel free to PM me, I'll be glad to help as best I can.
Mxr300ex
Did you go as far as the other guy did. They both look sick. If not what was your process
Yes, you have to sand it before you polish it because the frames not smooth.
why not anodize the frame? would be pretty sick if you could do it...
That would look sweet until your boots wore through...
