Problems in moab
Its all those pot smoking mountainbike riding hippies! :lol:
I'm not sure he's 100% correct, unless the law has changed again. I grew up in Utah and the law said that a bike could be registered with out blinkers if the bike originally didn't have them from the manufacturer so my XR250R just had the minimum DOT legal tires, horn, 1 mirror, head, tail, and brake lights.
You might be on to something there!!:worthy::banghead:
  • Similar Content
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
