08 rmz250 leak jet?
right now were riding in 30-45 degree weather at sea level.did the oring mod and just wondering what leak jet we should run,all i can get a hold of is a 35 would this be alright or should i wait until i can get a 40?
Leak jet size is also dependant on the riding conditions (tight single track, MX course, wide open fields/desert) and your riding style and ability. There is no one size for a particular bike/weather. Simply put, you have to test by riding to see what works for you. You weant the largest leak jet that eliminates the bog, after the oring mod or stiffer AP spring is done and you have set the AP timing. Leak jet selection is done last.
