Frame question
I damaged the frame on my '07 CRF250.....just to be sure...any 2004-2009 crf250 frame will fit right?
Thought it changed at 06. It may for but there is a difference between pre and post 06. I think.
I looked at the part numbers and every year has a different part number. It's a tough call without actually doing the swap. If I were you, I'd look for an 06 to 09 frame. My thinking is that they may have added a bracket or something like that which changes the part number. I know for sure the subframe is different from the 07 to the 04/05. Exhuast mounting for the duals.
I'd almost be willing to bet that they are the same. I've had them all apart, and I can't seem to think of any differences off the top of my head. They just might be the same. I'm 100% sure the engines will bolt right up on all the years.
Looking at an 05 frame....will the swing arm, linkages and front end bolt onto the '05 '07 subframe is still good...thanks for the help! I thought the '04-09 250F's are all 4th that would make them the same???
What's the damage?
I work at a welding/fabrication shop and aluminum welds can be very strong and reliable if you take the right precautions.
Some may think of this as a mickey mouse way of fixing something. But after seeing what kind of fabrications are possible, it wouldn't scare me to weld/straighten.
Just another option ya know? man my frame is not my '07 subframe is still good....think any '04-09 frame will work with the '07 suspension and front end?
i think you should be good with any frame. and when i was planning on putting a 2007 motor in a 2006 frame i called service honda. and they told me it could be done so i did. so i would give service honda a call. they know their stuff. and i can't help did you manage to mess up one of those frames?
2008 and 2009 there where slight changes with the fram with the adition of the hssd which also i belive moves cdi mounts around asthe 07 and older cdis mount center behind the front number plate, as for suspension it should all mount up with out modification, thaty havnt really changed the swing arm, but i belive in certain years they changed the rake it in the fram which i belive was in 06 n 07 and then in 08 they came out with the different offset clamps which work great.
Thanks for all the help gents...I went with an '06 frame. :lol:
Realizing that Honda went twin pipe in 06, has anyone else looked into the differences in frames between 04 and 07? I'm looking for a frame for an 06' and want to be sure I get the right one!!!
I do know that the sub frame bolts up differently on the 05 than 06. So they are for sure different those years.
Frames from 04-07 R's are interchangable, 08-09 slightly different due to steering stab. When Honda went to the twin pipes in 06 all changes to accomodate the pipes were made to the sub frame leaving the main frame unchanged. The mounts on the main frame for the sub frame are in the same location for all 04-09's.
another option if you ran accross one is the 250X frame is also interchangeable. You will have a bracket added for a kick stand but the motor and all other items bolt up the same.
I have an '04 CRF250X frame that I titled and converted for a CR500 motor.
I need a donor bike for everything but the frame.
Anyone know for sure what will work?
You can make any frame fro 04-09 work as others have stated before me, but dont forget about the resale of the bike when that time comes!! If I was a buyer I would have reservations about a frame swap..(what else did you do? would be my thoughts). If it were me I would try to get an equivalant or newer just for that reason!!
So any 250R or 250X donor will work?
I'm not worried about resale.
Anybody have a CRF250 with a blown motor? :ride:
I'm after the same thing with the CR 500 motor. I would like to keep the stock frame for the CRF250 for summer riding and then convert a second frame for a CR 500 motor for winter ice racing. I know there are some other things like the airbox that I would have to get two of, but I could have two bikes for different seasons with one set of running gear other than the frame.
I heard that the 2001 CR250 frame was a better donor for the 500 motor. I never did the swap, but that's what I heard from folks that have done it. I would think that it would be a lot less fabrication work, but I would also think that some of the upgrades on the newer 250F frame would be the reason why it would be desirable.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
    • By Throttlejockey
      Please post pics only. All other posts will be deleted so it doesn't get out of hand. PM the poster for more info or create a post.
      Violators will get a one day ban from the forum.
    • By bull413
      I checked the valve clearance on my 06 crf250r and both exhaust valves is at .007 and the intake is (left side) .005 and (right side) .000??? idk my feeler gague only went down to .002 and it would not slide in.
      Is that ok for the exhaust? Do I need to just shim the right side on the intake? or does both need shimming?
