KX65 Where exactly do the copper washers go?
got an '01 kx65. i'm going to install new reeds and spacer to lower the hit and increase low end power.
i see others who have added 'copper washers' to the exhaust.
i assume you add them between the exhaust port and pipe???
where do put the additonal copper washers???
right where you said - between the exhaust port and pipe. you just stack them - it plays with the way the pipe works by extending the distance.
thank you.
