Valve for spring
Do I have to revalve the shock in order to use a heavier spring on a KTM 300xcw? I'm told the spring will over work the shock and boil the oil out. thanx for your help.
depends on how much stronger the new spring is compared to the one you are using now.
If you just get one step up with the spring it might not be necessary, if you go stronger than that, you should.
It always makes sense to at least stiffen the rebound when you go stronger on springs.
