525exc high altitude jetting
i just bought a used 2005 525exc. it looks like it might have a paint faded JD blue needle in it. the current set up is:
1- does any one know the jetting suggestions that come with the 525 JD jet kit?
2- are the RED and BLUE needles in a jd kit the same for all FCR carbs/bikes? ie, is the red needle from a wr450 the same as the red needle im missing?
3- is there a 525 jetting data base? (like the drz one)
i need a good high altitude base setting. 4000-8000ft 15c(60f)to 25c (80f)
thanx for any help
simon
thanx for any help
simon
Paint faded blue needle 3rd groove from the top
170 main jet
small oring over accell pump linkage
1.25 turns out on fuel air screw.
small oring over accell pump linkage?
Yes. The directions come in the JD kit. Somebody might be able to post a copy of the instructions for you.
thank you!
i saved the picture and enlarged it ut it is kinda blurry!
can you please email the scan in a bigger format?
simon8965@hotmail.com
Email photo sent. Just click on the small photo and open it with
your own photo software.
