did dry rebuild
By the way, I stuck in a JE piston a month ago. I did the bone dry assembly method.
Before the new piston, the bone stock the bike would burn oil. Quite a bit actually, the dip stick would always read low after filling it. So I'd fill it, ride it and it would be a 1/4 down the stick after 2 hours of riding. Like clock work.
With the JE piston and the dry rebuild, I have not had the need to top off the oil ever. I change the oil every 12 hours and every bit of oil in in there after 12 hours.
I won't lie, I was nervous about the completly dry thing. Thought you all were crazy. Guess not. Will be doing it on my ICECUBE. :lol:
Just did my second dry rebuild with a new JE Piston last nite. NEver had any oil burning probs either. Lots of opinions out there though, KELSTER said its the only way to go!
Is that like trails...or hard mx?
Lots of hours on oil the oil for a honda (with so little to start with....)
I would like to see sunruh's take on that (anyone remember how many hours his intervals were?)
But seems you've had no issues....so must work:thumbsup:
It is MX but I am more of a low/mid range rider.
I follow what the manual says as far as intervals for service for many reasons. I'll be sending in my oil for UOA shortly so we'll see if I am crazy or not. I suspect the oil in in great condition but we'll see. If not I'll adjust but then it will be based on emperical evidence not annecdotal, speculation or gut feel.
I'll post the UOA. I could nto before becasue I had to add oil after every ride. With my JE and dry build I can actually send 12 hour old oil out for analysis.
Why not just rebuild it using some lubricant from ring manufactures like childs and alberts or total seal Quick seat instead of wearing all those little micrscopic pieces from your ring and imbedding them into your new piston skirt and also running the risk of a process called micro welding where the aluminum transfers metal to the ring causing a bit of compression loss and performance decrease .I have seen as much as 7 hp loss from rings on 1 cylinder because the ring did not seat properly there was no smoke or oil consumption .if you want to lap a ring into a cylinder it should be done with a very fine diamond lapping compound and in a dummy cylinder so that all the microscopics particles can be washed away before asembly into the cylinder be used and that should only be done with tool steel rings the new moly coated or filled rings would not require lapping on the face only the land surface.I know that some of you have had good results from the so called dry rebuild but you dont know what your missing .
I used Quick Seat on my last rebuild and it worked great.
Got it from Jegs.
Yep, I'll be using a dry assebmly lube. Dry as in "not wet" not as in "no lube" at all.
what so you guys mean by dry build, I was having a oil burning problem and just rebuild my top end but I used oil to lube the piston, rings and cylinder
You said you DID the BONE DRY METHOD now you say you WILL use DRY LUBE....Have you done it or not?? me think you did it with no lube whatsoeva & now ron has spoken you are crapping....
I did bone dry, it worked really well. I would have done dry lube on the pin actuallly but I neglected to get it and just got impatient. So I was a little worried about being totally dry, as I mentioned.
I will do dry lube this time though becasue I have dry assembly lube this time, at least on the wrinst pin. Other than that it will be bone dry.
did you notice any bump up in power at all?.....and let me get this straight, you sent your oil in to get it tested to see if it was wore out or not??? i would be intrested in seeing what the results showed
what is a dry rebuild, and what is the differnce between that and what Ron said?
As far as bump, it is hard to say. I mean yeah I did but I also went to 13.5 piston. I'l tell you this, the overall effect was a lot more than I expected from a slight compresion increase. The bikes power delivert feels very different and is not nearly as lazy as it was.
I used to burn alot of oil and that was with a bone stock bike, and the head was filthy. Now I burn no oil at all. I assume the head willl be cleaner this time around.
I am sending it in in a few hours. It will measure oil shear and viscosity. I am bettig after 12 hours oil analysis will say that the oil is in very good shape.
what about overall power? my 06 has bone stock motor and from what i can remember (last riden in november) it burned some oil, i think i am gonna do a piston this spring but dont want to be throwing my money away.
that should put a little damper on the oil controvercy, i may base my oil change frequency on what the results showed
Dry build is as it sounds a build with no wet oil. Some use dry lube some use nothing. People claim benifits and problems on both sides.
If you search for dry build you will find many threads on it including Rons elaboration on what he said earlier. Not sure how much is theory and how much has been actually detected with an electron microscope. What he says makes sense but I am not totally sure it has any real effect or is a real effect. It may be more theory than fact but even if it is fact it may not be an issue at all just a foot note. I don't know.
It maks sense to me to use dry lube on the pin though. Any bearig needs some lube, but sliding/seating surfacs should be dry. When the motor runs it splashes oils up there is real short order. I do not subbst starting the bike after a dry bulld and pinning the throttle, rather let it idle for 10 or so seconds before headoing out for normal break in procedure. Just my opnion, it makes sense, no real R&D to support this.
Dry builds happen in cars too btw. We are talking top ends not bottom ends.
Hey, I just go tthe Athena kit. I'll put it on in a week or so. I can send you my JE 13.5 if you want it. It has about 10 hours on it. Just buy new rings and go. No charge. :lol:
ha your kinda a crazy guy. first you wan to put a ice cube kit in it, then you quick put in a JE, now you want a athena kit? lol
you mean 10 hours now or your assuming you gonna put 10 on it? i will wait untill you decide to take it out then we will talk about it :lol:
Oh damn I want it im in state! Starving racer! I put oil on the wrist pin, not enough to drip on the cylinder but enough for a couple seconds cold start. The kick start lever feels a lot stiffer doesn't it?
You always want to put some oil on the piston pin. It has nothing to do with the rings sealing. The only oil on my cylinder is the residue from the ATF that I wiped it down with, and then used clean paper towels until no more ATF comes off. You turn it over by hand 50 times slowly with it dry, so no micro welding as previously mentioned will happen. You then fill it with oil, start her up, let it warm up, and ride the piss out of it (without hitting the limiter) and never let the revs go very low. The idea is to keep the cylinder pressure up. I did this with both of my CRF250Xs and they both don't burn any oil. The first CRF has over 120 hours on it and it still doesn't burn any oil. I did takes some advice and put a small dab of oil on the piston skirt this time, and I don't think it is as good as totally dry. It is not burning oil, but doesn't seem as potent. YMMV
Also, my educated mind says an engine that is not burning oil has a good ring seal, so if it is down on power, I would look elsewhere. :lol: .
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
