Canister Storage Mounting on a DR-Z
I have seen where the "Operator's Manual Canister" sold by ASC is recommended for use for storage on a motorcycle. The canister is made to store an operators' manual on a garden tractor.
I thought I would try it.
Here is how it looks on the bike.
Here are the parts.
Hardware Needed:
two 77/95mm hose clamps
two hex bolts 6mm x 20mm
3 6mm nyloc nuts
one hex bolt 6mm x 15mm
2 flat washers
5 5/8" length of 1 1/2" x 1 1/2" x 1/8" aluminum angle
2 1/2" length of 5/8" aluminum flat stock
The operator's manual canister item # is 67670 from ASC.
Their URL is www.agri-supply.com
The canister was $4.99 plus shipping when I bought it.
The canister is about 12" long and about 3 1/2" in diameter.
There were mounting brackets on the canister. I cut them off and used the hose clamps to mount it.
There is a drain hole in the canister. I plugged it with a screw.
Shipping was $9.98. You might want to go in with some one else and buy two of them to cut down on the shipping.
I just drilled the large holes in the aluminum angle for grins. You might want to do a better job of lay out than I did.
Good luck getting the yellow lettering off the canister. It was a PITA.
I have no idea how well it will hold up. It has been too cold to ride since I mounted it.
