Alarm woes (was: Anyone got a Remus Freeride?)
Reason for asking is that I recently bought a DRZ400SM with one fitted, but the previous owner had seen fit to ride without the baffle.. inevitably, he'd lost it so I'm riding without. However, it's a bit too loud for my taste, so I ordered a replacement.
It duly arrives, accompanied by a bolt, a washer and a funny pin-like thing. The baffle fits into the can just fine, and there's a hole in the can which matches the hole in the baffle, so I assume the bolt simply screws into the hole, and it's fitted. Right? No! The hole has no thread to accept the bolt. Aside from that, how one is expected to screw anything into the hole with only the 1" aperture in the baffle to access it is another matter... ?!
Anyhow, point being... I'm completely.. er... *baffled* as to how the hell I'm supposed to fit the damned thing!
Any ideas?
is it a yoshi system if so you need the end cap for the muffler
that part it threaded.
pay attention class, the man said its a REMUS system
never heard of it
I have the Remus Ti slip-on. The bolt securing the the baffle had a tack weld holding it in place to the baffle. I think it was a 6-7mm bolt and released with a short sharp shock. The hole inside the can end should be threaded....unless its been stripped at some point.
mm.. ok, thanks. Looks like the thread's been stripped. I guess I'll have to try and force the bolt to cut a new thread on it's way in...
Failing that... I've got the OEM exhaust.. I might try fitting that and see what happens to performance. It'd be nice to actually use the engine properly without the acute embarrassment that accompanies opening the throttle!
Try B+Q, they should stock a larger size self taping bolt.
I managed to get it to tap into the remains of the thread, so it's fixed for the time being.
No idea what difference it's made as I've just spent 4 hours trying to work out why the alarm/immobiliser threw a fit. Most of the time it panics and sounds the alarm every 45 seconds, and on the rare occasion I can get it to reset, the bike's totally immobilised.
**** it, I give up. I don't doubt that's it until next saturday when I get some more time to play with it, and now I'm stuck on the ****ing train all week.
Sounds like the tilt sensor might be shot, if it's an old unit they wear and are prone to going off randomly.
hmm, that's a thought. I did actually try holding the bike upright to see if it helped, but it made no difference.
It's a Datatool S4, 2 years old. According to the user guide, the long beep means it's been triggered, and the following beep(s) are the diagnostic code.
I see either one or two diagnostic beeps. The book informs me that one beep means the fuse has blown, two means the alarm was triggered by me disarming with the ignition on.
So, from the beginning... this all started because I was unable to ascertain whether pressing the button was doing anything or not. No flash of indicators, no apparent activity on the LED. It's done this a few times so I will just turn on the ignition, set off the alarm, turn off the ignition and disarm. This morning I think I forgot to turn off the ignition before disarming. Ok, oops.. my bad!
I read elsewhere that if there's no flash of the indicators, the fuse is blown and the unit is operating from its internal battery. Power to indicators is cut by design, to conserve power.
The book goes on to inform me that to reset the alarm I should disarm and turn the ignition on. Ok, no problem. I wait for it to alarm, disarm, turn the ignition on. No life from the LCD.. Diagnostic code is one beep.. 45 seconds later, it goes off again.
So, I'm stuck with the damned thing, disarming it every 45 seconds. Once in a while I clearly perform the magic function which disables it cos it will beep a few times, then just immobilise and cause no further problem until I try to disarm it. I've yet to work out exactly *what* the magic sequence is, but typically it involves the ignition and the clutch and/or kill switch. Fiddling with all three might tempt it to calm down.
However, once this has happened, any attempt to disarm it results in it going haywire again... FFS!!!
So, a little reading round and it would seem these devices eat fuses if provoked, and the evidence I have would suggest this might be the problem. Once I'd located the damned fuse, I see that it appears to be perfectly intact. It's a solid wire type (not sure what the term is here..) where you can see the physical damage if it's blown. As mentioned.. the fuse appears completely sound.
So, I'm totally stumped. I've no spare fuse just yet so I can't try changing it.. although I guess I could just try the 20A spare from the main circuit as a diagnostic. I'm not gonna try this tonight as I've totally lost patience with the f'ing thing. I don't doubt my neighbours would agree!
Could it be the bike battery is failing? It's most likely the original battery, and the bike is 2 years old. I didn't have my multimeter with me so couldn't take a reading, and the bike is garaged away from my house.. I really don't have it in me to go and look at it again tonight, but next time I will check that.
Any thoughts gratefully received.
I have that same alarm on my gixer, it does something similar when the bikes battery is low.
Try charging and/or changing the battery or using your spare remote.
Yeh, that sounds like a good idea, thanks. :lol:
If the voltage is notably down, I might try and hook up the TDM via the jump leads and see whether it boosts the battery enough to keep the alarm happy.
That would help stabilise the voltage for a while.
Sure enough, my multimeter reads a paltry 5.5V from the battery. Hooking it up to the running TDM to it provides a healthy 12-14V, and the alarm works normally.
I'll have to take it out for a spin to see whether I can re-charge it.. could be that the 30 odd minutes of the alarm sounding (before I found the manual to work out what was happening) flattened it in the first instance, provoking it further.. with luck the battery's ok!
If i need to replace the battery, does anyone have any recommendations?
Fingers crossed! Most recommend the Yuasa battery.
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
