susp.questions 07 crf250r
I weigh 180lbs. what springs and set up are the best thanks
Stock Spring Rates:
Fork: 0.45 kgmm
Shock: 5.3 kgmm
Recommended Spring Rates:
Fork: 0.43 kg/mm
Shock: 5.2 kg/mm
Recommended Springs:
Fork: 4349544
4349542
Shock: 646726552
646726551
Per mx-tech.com spring calculator.
I thought the bike was setup from factory for someone 180lbs., this calculator is showing a big difference?
180-200. You should be fine once you set the sag and play with the rebound and compression. What Woodracer250 has listed for you is 100% exact to your weight. But with companies like mx-tech, race-tech, pro-action, ect, they're much more precise.
180-200.
I run stock springs and I'm just fine w/ them. I was on the edge, but I'm glad I didn't drop the coin for something I didn't need. :p
